JJB*
Flight distance : 12401030 ft
Manitobahunter Posted at 2-26 20:27
On the RC2, go into the main settings menu, scroll down to the bottom under the safety tab, click advanced safety settings, and scroll down to the bottom again, theres a blue switch labeled Vision Positioning and Obstacle Sensing . It's hidden a bit, likely for good reason A great feature for the use you mentioned, but I'd never use it close to the ground...
So:
Settings, Safety, Advanced Safety Settings, Vision Positioning and Obstacle Sensing
in addition to post#2 (all correct)
DO NOT FORGET TO ENABLE AGAIN BEFORE LANDING!!
Tested it out to land with disabled sensors and it can be a very hard landing if you are not really smooth smooth smooth on the stick.
cheers
JJB
