Machoman
Flight distance : 1036959 ft
Austria
I make a new thread ONLY for this detail because its important and there is too many threads discussing X5 all and everything.
Now the only thing we really know is this:
Zenmuse X3 Gimbal with Camera Weight | 247 g |
Output Power with X3
Static: 9 W
In Motion: 11 W
Zenmuse X5 | Zenmuse X5R | General | Dimensions | 120mm (W) x 135mm (H) x 140mm (D) | 136mm (W) x 125mm (H) x 131mm (D) | Weight (Standard Lens, Balancing Ring, Lens Hood, Micro SD Card Included) | 526 g | 583 g | Static Output Power | 8 W | 19.5W | Peak Output Power | 13W | 25W |
available data on flighttime at payload is poor (have not found for Inspire) in this table of similar Matrice 100 it may give a hint.
Hovering Time (with TB47D battery) | No payload: 22 min; 500g payload: 17 min;1kg payload: 13 min | Hovering Time (with TB48D battery) | No payload: 28 min; 500g payload: 20 min;
1kg payload: 16 min |
| Hovering Time (with TB47D battery and Zenmuse X3) | No payload: 19 min | Hovering Time (with TB48D battery and Zenmuse X3) | No payload: 23 min |
conclusion at available data:
I would assume the effect of weight difference alone will be:
X5 TB 47 -2 min
X5 TB 48 -3 min
X5R TB 47 -3 min
X5R TB 48 -4 min
However I dont know how to calculate the effect of the different power consumption.
Anyone ideas?
