RC Motion 2 joystick won't calibrate
1864 6 2024-2-27
Dean Porter
I have a new Mini Pro 4 with Integra goggle and RC Motion 2. It flew a total of 5 hours with no problems. Now when I power up the Motion 2 starts rapidly beeping. Status error reads "Motion controller or joystick error." Compass and IMU calibrations are good (green). The accelerator and joystick calibration is red. When I attempt to calibrate, the accelerator is ok. However the joystick does not have full movement on left (72% and down (48%). Up and right are 100%.
I have shut down and powered up multiple times and I have updayed the firmware (on joystick, aircraft and goggles) 3 times in the last day.
Please help me.
2024-2-27
DJI Gamora
Hi, Dean. Thank you for reaching out and we're sorry to read about this. Please ensure that you calibrate the remote controller and its dial. If the issue persists or stick movement is partial during calibration after fully pushing the stick, please apply for an “Online Repair Request” and send your product back to DJI for analysis and solutions.
2024-2-28
Hannes Zietsman
South Africa
DJI Gamora Posted at 2-28 00:43
I have the same problem with my M2. its stuck at 72% left and the throttle don't work as normal. it is full back all the time except if I move it. I have reflashed it and tried to pair it again but nothing works.
2024-9-24
DJI Tony
Hannes Zietsman Posted at 9-24 01:03
Hi there. We are sorry for the inconvenience. Could you please describe your problem in detail and provide relevant pictures so that we can better help you?
2024-9-24
J
Flight distance : ****
Brazil
RC Motion 2 - managed to solve calibration error
Devices used:
- DJI AVATA;
- GOGGLES INTEGRA;
- RC MOTION 2;
I was also having problems calibrating the throttle (right after takeoff the drone started moving backwards and upwards without any commands). After some hours of trial and error I managed to solve the problem, at least for now.
I downgraded the firmware of the Goggles and RC Motion 2 to the previous version (using DJI Assistant 2 - Consumer Drones Series). When starting the devices, the joystick and throttle error continued. I performed several calibrations until I was able to actually get the message "CALIBRATION COMPLETED" (something I was unable to do even once with the updated firmware). All the joystick positions reached 100% when moved and the throttle calibration bar was centered so that when pressing the lever, the bar fills up all the way to the right and when pushing it, the bar empties to the left.
Now when I reconnect the devices, they all link without any error.
I hope this can help you, give it a try and send the feedback if possible.
1-2 08:26
DJI Tony
J@ck@0 Posted at 1-2 08:26
Devices used:
- DJI AVATA;
- GOGGLES INTEGRA;
Hi there. Thank you for sharing, we believe this will be helpful to many people.
At the same time, if you encounter any problems in the future, please feel free to contact us.
1-2 22:46
Paulo Dsilva
India
Yeah it still happens, the throttle is not going to 100% and is bouncing back and forth a little even after pressing the throttle completely. I have Avata 1 and it randomly starts to fly backwards as if the throttle is pressed backwards and on full throttle forward it slowly moves ahead but not at full speed.
2-2 10:22
