Dji Mini 3 Pro Jello Efect
453 14 2-27 10:54
BRS64
Flight distance : 3113789 ft
Turkey
Hi All;
I have read lots of treats about mini 3 pro jello efect, also i have similiar experience but it is very rare. Today i realized that it happens only vertical mode and while going up and backwards. At the other scenarios there is no problem. What do you think about this? I think gimbal quality is not best option if you compare with mavic series.
2-27 10:54
DJI Tony
Hi there. Will it be fine if you show us a video? You can upload it to YouTube or Google Drive and then paste the link here. Thank you.
2-27 20:13
Bashy
Flight distance : 2354357 ft
Make sure all the props are A ok, no nicks of any sort, not bent from being in the prop holder etc...
2-27 22:31
Serg SSA
Flight distance : 6406329 ft
Russia
You must show what it looks like. I've never had this problem before.
2-27 23:21
DAFlys
+1 check your props,  this is the number 1 cause of vibration.
2-28 01:57
BRS64
Turkey
Here is the video!
https://youtube.com/shorts/TIf_aCzwbVA?si=_9vIUlS04PxA5bLx
2-28 11:31
BRS64
Turkey
DAFlys Posted at 2-28 01:57
One matter that i did not understand, why only flying up and backwards. If the props are defective, does not it efect all types flight?
2-28 11:34
DAFlys
BRS64 Posted at 2-28 11:34
Flying backwards like that will be changing which props are doing the majority of the work as the attitude of the drone will be different.
Did you check your props?
2-29 01:16
BRS64
Turkey
DAFlys Posted at 2-29 01:16
here is the link, everything looks perfect.
https://drive.google.com/file/d/ ... 7j/view?usp=sharing
3-1 10:17
DAFlys
BRS64 Posted at 3-1 10:17
https://drive.google.com/file/d/1iuJpBZCUfsBgBdJ9cpTYI7Vvjoxwm97j/view?usp=sharing
Have you inspected the props though?
3-2 00:50
DJI Tony
BRS64 Posted at 2-28 11:31
Here is the video!
If the drone has ever crashed or experienced any collisions, we recommend sending the drone for diagnosis. If not, can you please follow  the steps below:
1. Please check whether the ambient temperature during drone operation falls within the operating temperature range provided on our website. Low temperature may cause vibration in the gimbal.
2. Kindly remove the gimbal protector before powering on the aircraft to prevent the gimbal motor from being stuck, or the gimbal will become shaky.
3. Please make sure that the gimbal is in Follow mode. If it is set to FPV mode, the gimbal view will be tilted when the aircraft tilts.
4. Please check whether the aircraft is in Sports mode (S-mode) when the gimbal becomes shaky. In S-mode, greater emphasis is placed on flight performance. During flight, when the aircraft attitude is too large, the gimbal attitude stabilization cannot be guaranteed. If the gimbal is shaky in S-mode only, which is normal, please switch the flight mode of the aircraft to Normal mode (N-mode) or Cine mode (C-mode) to achieve a more stable view.
5. Please check whether the wind was strong in the flight environment. If the wind is too strong, the aircraft will vibrate, resulting in the image transmission screen being shaky. We recommend that you test the gimbal in a windless or breezy environment.
6. Have you ever adjusted the EXP value of the aircraft? EXP refers to the drone's exponential. The higher the EXP value, the higher the aircraft response sensitivity, indicating that the aircraft will respond flexibly to small stick movement. If you have ever adjusted the EXP value, please go to [Control -> Gain & Expo Tuning] in the app, reset the parameters, and then test the aircraft again.
7. Please perform gimbal calibration in the app. Using with DJI Fly: [Settings -> Control -> Gimbal Calibration].
If the steps above were done and the issue persists, we advise submitting an Online Repair Request and sending the aircraft back to DJI for further diagnosis. https://repair.dji.com/. Please keep us posted. Have a great day ahead.
3-3 03:35
BRS64
Turkey
DAFlys Posted at 3-2 00:50
yes. I checked them.
3-3 07:19
BRS64
Turkey
DJI Tony Posted at 3-3 03:35
Thanks for feedback. I saw recommendations about IMU calibration and adding ND filters at some treats.
What changes if i apply these?
3-3 07:23
DJI Tony
BRS64 Posted at 3-3 07:23
Hi there. IMU helps keep the aircraft steady but not the gimbal and the ND filter adds weight to the camera. Have a great day.
3-4 03:27
Montfrooij
Flight distance : 2560453 ft
How is it going now?
3-17 10:05
