DJI MIc 2 question
635 16 2-28 08:47
fans40c3d707
Flight distance : 1607267 ft
Hi
I have enabled bluetooth on 1 of my transmitters and connecting to an external camera.
However the audio is badly distored and I think its just being overloaded.
If I repair the TX with the RX and adjust the gain DOWN on the mic by a lot.
Will this reduced gain be used when I pair with bluetooth again with camera ?
thanks
2-28 08:47
fans40c3d707
Anyone know answer to this ?
3-2 02:20
DJI Gamora
Hi, fans40c3d707. Thank you for reaching out. May we ask what camera are you using with the DJI Mic 2?
3-3 20:16
fans40c3d707
DJI Gamora Posted at 3-3 20:16
I use 2 camera's.
Iphone 14 pro & Insta 360 X3
3-3 21:44
DJI Gamora
fans40c3d707 Posted at 3-3 21:44
I use 2 camera's.
Thank you for the reply, fans40c3d707. Does the issue persist on both devices?
3-5 04:28
fans40c3d707
It's when I am using bluetooth connection the sound overloads. The audio via the rx is fine but I need to use bluetooth from time to time. (but cant)
3-5 06:50
DJI Gamora
fans40c3d707 Posted at 3-5 06:50
Thanks for the reply, fans40c3d707. Let me forward this to our relevant team for further checking. We'll let you know once we receive an update.
3-9 01:49
fans40c3d707
ok, thanks, Just to add I have the gain set on camera for audio to -18db
3-9 01:51
DJI Gamora
fans40c3d707 Posted at 3-9 01:51
Thank you for the additional details, fans40c3d707. We'll forward this one as well. We'll keep you posted once we receive feedback. Thank you for your kind understanding.
3-10 19:44
DJI Gamora
Thank you for patiently waiting, we have confirmed that if you first connect TX to RX, reduce TX gain, and then switch to Bluetooth mode to connect the phone, the reduced gain parameter will not be used at this time. Hope this helps.
3-12 04:31
fans40c3d707
DJI Gamora Posted at 3-12 04:31
ok, thanks
I suspected that was the case.
Is there anyway to reduce TX gain when in bluetooth mode ?
thanks
3-12 04:34
DJI Gamora
fans40c3d707 Posted at 3-12 04:34
ok, thanks
Hi there. Let me confirmed this with our relevant team.
3-17 17:49
DJI Gamora
ok, thanks
Hi, fans40c3d707. Thank you for patiently waiting.  If you have an Acion 4 or Pocket 3, you can connect to DJI Mic 2 via Bluetooth to adjust the gain; If you are not connecting Action 4 and Pocket 3, but just connecting the mobile phone through the transmitter Bluetooth, the gain of the transmitter will be retained according to the previous settings. Hope this helps.
3-18 20:47
fans40c3d707
ok, thanks, I have not been able to replicate the gain reduction set on microphone when pairing with a 3rd party camera.
3-18 21:32
DJI Gamora
fans40c3d707 Posted at 3-18 21:32
Hi, fans40c3d707. A Transmitter Bluetooth connection is recommended for Action 4 / Pocket 3 and mobile phone use. It is not recommended for other devices. The problem with distortion is that the connected equipment has not been adapted and has nothing to do with gain.
3-28 04:27
fans40c3d707
Yes, the microphone (mic 2) is connected to action camera (paired). The adjusted gain pre pairing (on mic 2) does not reflect in action camera sound.
3-28 04:45
DJI Gamora
fans40c3d707 Posted at 3-28 04:45
Hi there. Can you please provide a video showing the issue? We will wait for it. Thank you.
4-8 03:40
