linear / mapping mission
204 0 3-1 02:09
djiuser_pz4sLRjwTxOe
Flight distance : 52579 ft
Namibia
Hi Everyoneim glad i dound this forum i need you experienced guidance in the below survey
I am  flying  with GCPs  a RTK mobile station with m300 p1 zemuse 35mm
i have a 183 km LONG area to survey a pipe line and powerline
my observation:
some flight bands are not constant, within the area especially around the mountainEous area, it extend from centre line to 500 m on either side, and runs down to a river and then up a mountain again , some areas  to just 200m from the centre line.
QUESTIONS:
1. can i break the area into mapping mission for larger areas and some linear missions? im searching for efficiency
My GSD limit is 5cm, FOR CLIENT
my flight altitude will that need to be constant throughtout flight area to process in chunks?
3. some areas flatter i can fly lower, some areas with mountain peak i have to fly higher processing together
will that effect my output if i process with vary GSDs  and varying flying height
4. will Follow Terrain assist me on my DJI Pilot  2 for my planning
does itif I fly at 120 meters altitude and varying elevations of area,
Will  my drone adapt its flight alitude to accomplish task during Mountains and Rivers?
Hope to hear soon
thank you
3-1 02:09
