USB cables
209 5 3-2 17:22
CaptCrunch
Flight distance : 10873 ft
Is there something special about the cable that comes with a RC-N1 controller? The manual seems adamant about which end of my cable goes where. And I don't know why because each end of my cable has a USB-C connector. But I just do what the manual says. They look just alike to me though except one is marked to plug specifically into the controller.
So now I'm going to need a longer cable, with a C connector on each end, to reach a tablet on a tablet holder. And when I went shopping, I soon realized not all usb cables are the same. Some are only for charging, some don't do video, and I don't have a clue what I'm looking for.
Has someone else here been down this road before and can point me in the right direction?
3-2 17:22
Sean-bumble-bee
Flight distance : 15997 ft
There is something known as an OTG plug but I DO NOT know if it is applicable to USB-C. ...... Perhaps you could google it ?
OTG IS applicable to the older micro USB connectors and does something to the socket, the micro USB OTG plug has an internal connection between two of its pins that a NON OTG plug does not.
3-2 18:27
Labroides
Flight distance : 9991457 ft
No
Get any generic cable that fits and suits your purposes.
But don't get a charge-only cable, you need one that handles data as well.
3-2 19:27
CaptCrunch
Sean-bumble-bee Posted at 3-2 18:27
Tried googling USB OTG and pulled up lots of hits but I couldn't make heads or tails of what it is about.
3-2 21:44
CaptCrunch
Labroides Posted at 3-2 19:27
No
I tried replacing the original short cable with the longer cable that came with the drone. One end of the longer cable had a USB-A connector though so I had to use an A to C converter on that end. But it provided "no connection between the controller and the mobile device" (my phone). Problem may have been the converter or maybe it was just a charging cable and not a data cable, I don't know. But I've ordered a cable now with C connectors on both ends and it claims to be USB 2.0.  I think that must mean power + data cable.... not sure. But it won't be in for at least another week. So we'll see what happens then.
3-2 22:04
DJI Tony
Hi there. It is suggested to use the provided cable to ensure compatibility. However, most cables are also available for usage. It is recommended to use a data cable if you want to replace it with a longer one. Have a great day.
3-4 02:24
