Recommended SD cards? Sizes? Is 256 GB plenty?
370 7 3-4 13:17
djiuser_Qsrbvo63C9Nw
Austria
Hi everyone, as I asked in the subject...
Which SD cards have you tried? Would 256 GB be more than plenty if I film strictly in LOG for highest quality? Or is even 128 GB enough for a few hours of video?
Thanks,
Roman
3-4 13:17
Bashy
Flight distance : 2354357 ft
256gb will give about 4 hrs i was told, that was at 4k/120 - D-log 10bit, if shot in .h265 this should save on file size but it will run hotter.
3-4 17:39
Burt37
Flight distance : 4009 ft
Hi Roman
You may find this sites helpful...
https://www.omnicalculator.com/other/video-size
https://www.videoproc.com/edit-4k-video/video-size-calculator.htm
3-4 18:56
DJI Tony
Hi there. You can also refer to the recommended list on the DJI official website : https://www.dji.com/global/osmo-pocket-3/specs
Have a great day ahead.
3-4 19:30
DJI Gamora
Hi, Roman. Thank you for reaching out. Please see the recommendations of other users above for the microSD Card size. For the brand and type of microSD Card, please see the recommended models:
SanDisk Extreme Pro 32GB V30 A1 UHS-I Speed Grade 3
Kingston Canvas Go!Plus 64GB UHS-I Speed Grade 3
Kingston Canvas Go!Plus 128GB UHS-I Speed Grade 3
Kingston Canvas React Plus 64GB UHS-II Speed Grade 3
Kingston Canvas React Plus 128GB UHS-II Speed Grade 3
Kingston Canvas React Plus 256GB UHS-II Speed Grade 3
Lexar Pro 256GB SDXC UHS-I V30 R160/W120 (1066x)
Lexar Pro 512GB SDXC UHS-I V30 R160/W120 (1066x)
3-4 19:33
romanko
Austria
Hi everyone, thanks a ton for your responses!
I did my first tests and realize that the footage is recorded with about 80 Mbps whether D LOG or Normal color. So unlike the iPhone's Pro Res, this is not taking that much memory. 256 GB seems quite sufficient. Now on to finding time to learn how to get the best quality footage and how to quickly color grade, although it seems to me that when outdoors and good white balance, the color straight out of the camera is quite good, bit harsh, but good.
Great day everyone!
3-5 08:53
romanko
Austria
Bashy Posted at 3-4 17:39
Thanks! This is an interesting point. Am I correct that H265 should be used for the maximum possible quality out of the camera?
If H264's only disadvantage was the file size and its advantage keeping the camera cool, then H264 might be the preferred encoding.
3-6 01:57
Bashy
romanko Posted at 3-6 01:57
Hi, i could be wrong be google says its the same quality.
3-6 18:40
