Setting Home point problem
299 1 3-5 20:12
djiuser_JUBdHZUZ6X73
Hello,
I recently encountered a problem setting my home point during the flight. I can't update while flying. I have the latest apps and the drone is up to date. Everything else working fine.
3-5 20:12
DJI Gamora
Hi, djiuser_JUBdHZUZ6X73. Thank you for reaching out. To set the current location as the home point, the location must be identified using the GPS information from the mobile device. If the GPS signals from the mobile device are weak or if there's strong environmental interference at the current location, the setting of the home point may not be successful. Please move to a location where GPS signals are better and then set the current location as the home point
Note: Compared with Android devices, iOS devices have higher GPS accuracy requirements. Therefore, you may successfully set the current location as the home point using an Android device but could fail when attempting the same on an iOS device.
3-7 18:09
