Sharpen for Color Profiles
281 4 3-9 22:40
Drone.Hunter
Flight distance : 4537612 ft
Kazakhstan
Adjusting Sharpness for different color profiles gives different results. The Standard profile produces a sharper image than other profiles.
In the pictures the sharpness setting is +2 and -2.
Is this how it should be?
Sharpen: +2
+2
+2
Sharpen: -2
-2
-2
3-9 22:40
DJI Gamora
Hi, Drone.Hunter. Thank you for reaching out. Let me forward this to our relevant team for further checking. We'll get back to you once we receive an update.
3-10 22:33
DJI Gamora
Hi, Drone.Hunter. Thank you for patiently waiting. Here's the information from our relevant team: Because DlogM and standard are two different color modes and DlogM needs to use an LUT file to do the post-processing operation, so visually, the sharpness changes in standard mode are more obvious. Hope this helps.
3-12 03:17
Drone.Hunter
Kazakhstan
DJI Gamora Posted at 3-12 03:17
The picture shows the result after applying the LUT, which was downloaded from the site.
DJI Air 3 D-Log M to Rec.709 V1_.cube
3-12 06:01
DJI Gamora
Drone.Hunter Posted at 3-12 06:01
Hi, Drone.Hunter. Please check my DM regarding the topic we discussed.
3-18 22:26
