DJI Fly + Android 14 + OneUI6.0: not compatible?
6962 20 3-11 08:05
slam_dunk23
Flight distance : 27064 ft
I'm running Samsung Galaxy S22+. Since upgrading to Android 14, oneui  6.0 the latest official DJI Fly App (1.12.8) doesn't work properly. As  soon as I plug the phone into the RC-N1 and switch the RC-N1 on, my  telephone flashes a message every 30 seconds saying it has a problem  with the charger and that it might be faulty, even before launching the  app. The DJI Fly app no longer starts automatically when I connect the  phone to the RC-N1 and switch on the RC-N1. When i select the App it  opens but it does not connect to the drone. Quick transfer is available  in the App but it does not go to fly mode. The error message for the  battery charging continues to flash up on the phone whilst the app is  running.
I tried disabling fast charging on the Samsung phone but that didn't  change anything. I also tried connecting the drone by holding the on button on the Mini 3 PRO for 4 seconds to go into search mode, but that didn't help either. My old Samsung phone (A35 5G) with Android 13 works  perfectly well, starts the DJI fly app (1.12.8) and connects to the drone, so it's not a cable or RC-N1 issue. I did not bind the drone to the app on the A35 phone. It can only be related to the S22+ telephone itself. I've tried clearing the cache and re-installing the  app but nothing changes. I also tried older versions of the app without  any success. Since upgrading to Android 14 the app no longer connects to the drone.
I understand that developers can't test every mobile and OS version, it's a lot of work! So when DJI says it's working on Android 14, they need to say more about exactly what conditions it was tested under. Please do not answer this thread with just "it works on Android 14".
Has anyone had similar issues? How did they resolve it?
3-11 08:05
DJI Tony
Hi, slam_dunk23. Sorry about the trouble. Will it be fine if you post a video showing the issue when connecting your phone to the controller? Thank you very much.
3-13 03:00
slam_dunk23
Hi Tony,
Sorry for the delay in answering. Please find attached a photo showing the issue. I tried uploading a video but I can only attach photos.
I've just checked a couple of things. I also get a similar message when I connect a 15W charger, but not my high power 35W charger, see attached photo.
I also just tested the app and drone on my wife's Samsung Galaxy S24+ OneUI 6.1 phone and it works fine.
I suspect the issue is with my phone only. I've just cleaned my USB-C port and now the slow charger works, but the app still does not connect to the drone.
Any suggestions how I can fix this?
3-16 00:45
slam_dunk23
Good news, I've fixed the issue. I went into safe mode and the connection to the RC-N1 was fine. Following online recommendations I unistalled other 3rd party apps on my phone that I had installed recently and now DJI Fly is working.
3-16 04:35
William_Mavic3
Flight distance : 27503 ft
Galaxy Tab8 UI6.0 Android 14 DJI Fly 1.12.8 Won't respond past "Before You Fly"I have re-installed DJI Fly App, Re-set Tab A8 to factory and behaviour is same
Any advice much appreciated
3-16 07:03
William_Mavic3
3-16 07:15
William_Mavic3
Problem is now resolved - the tutorial icon needed to be touched and cycled through! Not at all obvious in terms of screen prompts so hope this post helps.
3-16 07:27
scott492010
William_Mavic3 Posted at 3-16 07:27
could you explain a little more? I am completely unsure what you mean by "the tutorial icon needed to be touched and cycled through". I am stuck in the same spot as you and i have stared at it forever. Then i stared at what you said and compared it to the screen and i still don't get it.
5-31 18:25
scott492010
scott492010 Posted at 5-31 18:25
I have figured it out. Took me a while but i just kept touching everything i could find on the screen until i believe that little white arrow led me to the tutorial you were speaking of.
Now it works fine. I even went on a test flight and had no problems.
5-31 19:11
Andrei Bogdan Oltean
Romania
Hello, the dji fly app stops working since the last update. What can I do? I sent you a picture of the phone.
8-16 22:34
djiuser_wK1oBGSkYtfd
Bahamas
Same issue on my pixel 8 pro, Please do something so I can fly my drone
8-20 17:56
Burt37
Flight distance : 4009 ft
Andrei Bogdan Oltean Posted at 8-16 22:34
https://forum.dji.com/forum.php?mod=viewthread&tid=316868
8-20 18:48
Burt37
djiuser_wK1oBGSkYtfd Posted at 8-20 17:56
8-20 18:48
DJI Gamora
Hi there,
We are truly sorry for the inconvenience you are experiencing. It is a known issue for DJI Fly and Mimo app. However, could you please specify the model of your device and whether you were able to use it with the DJI Fly app before encountering the current issue. We are looking forward to your response for further assistance. Thank You
8-20 23:08
DJI Gamora
Hi there,
We are truly sorry for the inconvenience you are experiencing. The relevant team are aware of the problem and urgently fixing it with the engineering team. We have send you an alternative method, please check your DM.
8-20 23:08
djiuser_Z6NKqyEiWyy6
Romania
Redmi note 13 + 5G nu mai funcționează aplicația pentru dji mini 2 SE.
8-21 09:13
DJI Natalia
djiuser_Z6NKqyEiWyy6 Posted at 8-21 09:13
Hi there, thank you for reaching out. We are sorry for any inconvenience. Kindly download the DJI Fly app via the link below to see if it works.
Link for DJI Fly app: https://pan-sec.djicorp.com/s/AyTTCperK58xbAy
Please keep us informed of the outcome.
8-22 01:40
uovi87
Flight distance : 656631 ft
Romania
Hello,
For the new Pixel 9Pro XL with Android 14 is the same issue. Application cannot be installed.
Can you please help with this?
Thanks.
9-4 03:49
djiuser_5wDwoPdHHnGf
Kenya
Hi, I am using Samsung A14 and it cannot install the application. What is the issue?
9-22 23:44
djiuser_KypwI1LmmqK6
Portugal
Tenho um s24 ultra estava tudo a trabalhar bem e agora a aplicação não abre. Desinstalei é agora não instala o que poderei dazer
9-24 10:31
Walter Lennon
Is there a software for Galaxy A14 androids?
10-7 07:29
