The Saint
Flight distance : 5902228 ft
I have a mac and I don't use it for any microSD card functions except copy, move, paste, and delete. As with any microSD card, the format function is generally used to clear everything off the card and basically start over. However, I would never format a microSD card on my mac that I intend to use primarily in the drone. Instead use, the format option in your drone and that will delete everything on your microSD card; do this after you have copied off and save everything you need because formatting or re-formatting is technically irreversible.
For the record, you will be able to delete the files off the Mac or the drone once you disconnect your drone from the mac computer. My answer is based on the assumption that "Internal Storage" is actually the microSD card inserted in your Avata. |
