DJI Thor
Flight distance : 13602 ft
Hi there, sorry for the late response. After checking, based on the video, the right side is slightly heavier than the left. The camera can be tilted on its right side up to an angle of 45°, but when you let go of the left side, it tilts towards the right, indicating that the right side is heavier. However, you can adjust the roll axis to keep it in a neutral position after letting go. It is suggested that you could fine-tune it with some minor adjustments to see if it works. Thanks. |
