DJIDronePete
Flight distance : 14360 ft
DAFlys Posted at 3-15 03:13
It may be moot as I dont think the firmware in the UK limits the drone to 50m like it does in the EU which appears to be required here.
The way that I see it could be used is:
* Use the parallel track mode (which is one of the most obvious modes to use)
* Fly the drone to say 20m away
* Lock it onto me as the subject in the active track mode
* Then, if I've understood the user manual correctly, when I move the drone will maintain the same relative location (based on its image processing) so will always be 20m away.
I'm intrigued by your comment that UK and EU firmware may be different (especially given that I will be taking my drone to Europe) - is the firmware really different? Especially (as below) there is no practical difference between the UK and EU rules in this respect.
I've checked the European rules (https://www.easa.europa.eu/en/do ... tems-regulations-eu) and they are identical to the UK drone code:
Article 4, para 1d: the remote pilot keeps the unmanned aircraft in VLOS at all times except when flying in follow-me mode or when using an unmanned aircraft observer as specified in Part A of the Annex;
by way of derogation from point (d) of paragraph 1 of Article 4, be conducted, when the follow-me mode is active, up to a distance of 50 metres from the remote pilot; |
