Can't Update DJI Mic 2 Firmware on Windows 11
442 5 3-16 01:48
Steve379
Has anyone been able to update DJI Mic 2 "Transmitter" on a Windows based computer? I've tried on two computers with no luck. Downloaded the firmware, followed all the directions and no success. The Receiver firmware updates fine. Every YouTube video showing updates to the transmitter show the process only on Apple computers
3-16 01:48
DJI Tony
Hi there. Sorry about the trouble. Please try the procedure below:
1. Download the firmware update package from the Downloads page of DJI Mic 2; https://www.dji.com/global/downloads/products/mic-2
2. Ensure that the receiver is powered off and the transmitter is on. Connect the transmitter or receiver to your computer using a standard USB-C cable;
3. Put the downloaded firmware update package (file with .bin suffix) under the root directories of the transmitters and receiver;
4. Disconnect from your computer, and the transmitters and receiver will start the firmware update automatically.
1. If the update fails, download and copy the firmware again and reboot the transmitters and receiver. Repeat until the firmware is updated successfully.
2. Remove the mobile phone adapter from the receiver before connecting it to the computer for firmware update.
You can also refer to the Mic 2 Firmware Upgrade Guide. Here is the link: https://dl.djicdn.com/downloads/ ... pgrade_Guide_en.pdf
I hope it helps. Have a great day ahead.
3-16 21:54
Steve379
DJI Tony Posted at 3-16 21:54
Thanks for the reply but no it doesn't work. I've tried the process many times. Can you confirm that the new Firmware upload firmware works on a Windows 11 based computer. Do you have a video or detailed instructions for uploading to a Windows 11 based computer. All the videos I've seen on YouTube show the upload on Apple computers.
3-17 09:43
DJI Tony
Steve379 Posted at 3-17 09:43
Hi. Are you having trouble downloading the firmware to your Windows 11 computer from the DJI website?
3-18 01:10
Steve379
No, once it's downloaded and I place the file in the Transmitter folder, nothing happens. Per the directions, the update should happen automatically. It doesn't.
3-18 01:46
amin hosseini
Hi, I get this error when trying to update. what should I do ? Update failed. Restart aircraft or contact DJI Support if the issue persists.(0x11010500044C)
3-18 07:31
