Pocket 3 - Pre-Purchase Questions
268 5 3-16 05:26
MsNikita
Hi, Currently in the UK and I'm in the market for a device which allows me to record 4k60 continously, therefore I have been checking those forums about the Pocket 3 recently since I'm interested in making a purchase. I've noticed a bunch of threads regarding overheating issues and I'm am concerned...
Am I correct in thinking that there are no physical differences between Asian models and EU models than the firmware or activation region? Since it has to comply to EU regulations regulation of a maximum of 48°C (Celsius)
Currently I have a Pocket 2 that's capable of recording in 4k60, however it'll often stop recording due to overheating issues, typically around 7-10 minutes in - As a result, I have stopped using it as it not fit for my purpose. I have since purchased a Sony FDR-X3000 (which does not overheat and stop recording) but has 4k30 limitation (I prefer 60fps).
Questions
1. Is it true that DJI doesn't currently offer any global warrenties on it's products, even though content producers often work overseas?
2.
Does DJI offer different firmware for different regions?
3.
Having being on the original Osmo beta program many moons ago, I remember being able to side load firmware on to the device. Could this be possible for Pocket 3 Firmware updates too? This way I can keep the activation region status.
4.
If I buy a Dji Pocket 3 Combo from abroad (in either Japan or HK) could I avoid the EU Regulations regarding heat limitations? Or would my device stop working due to overheating, as it would IF i had purchased a UK model?
Thanks in advance for your replies.
3-16 05:26
DJI Paladin
Flight distance : 318 ft
Hi there. Thank you for showing interest in DJI products.
- DJI original warranty can only be applied within the same region where you purchase the unit.
2. Does DJI offer different firmware for different regions?
- When using the DJI Osmo Pocket 3, the firmware version is the same with different regions. You may refer to the release notes of the product using this link: https://dl.djicdn.com/downloads/ ... elease_Notes_en.pdf
3. Having being on the original Osmo beta program many moons ago, I remember being able to side load firmware on to the device. Could this be possible for Pocket 3 Firmware updates too? This way I can keep the activation region status.
- We don't have this feature on the said unit. If you are referring to the EU temperature, please note that due to EU policy requirements, the temperature threshold cannot be set manually and the DJI Mimo app will determined the country code and set it automatically.
4. If I buy a Dji Pocket 3 Combo from abroad (in either Japan or HK) could I avoid the EU Regulations regarding heat limitations? Or would my device stop working due to overheating, as it would IF i had purchased a UK model?
- The temperature threshold will depend on the region where you are using the unit.
Hope this clarifies your query to us. Please don't hesitate to reach us if you have other inquiries. Have a nice day ahead!
3-16 21:47
DAFlys
Have you seen -
3-17 07:00
Arki
Poland
You can upload a text file called "crackconfig" (without file extension) with the text "heat test" to the memory card. As long as this file is on the card, the 48 degree limit does not work.
3-17 07:01
MsNikita
Arki Posted at 3-17 07:01
Oh interesting. Thanks for that.
3-18 19:21
Aavis
Flight distance : 328 ft
Finland
With Pocket 2 only use SanDisk Extreme cards. It never overheats. Kingstons wont work with Pocket 2 it stops recording under 10 minutes with different reasons. Pocket 1 and 3 works with Kingston cards but not Pocket 2.
With Pocket 3 EU firmware is optimized I have never seen any overheating message anymore. Recorded yesterday indoor over 1 hour. Forget the "EU overheating thing".
Ofc I assume you have the latest firmware. If your Pocket 2 cant record more than under 10 minutes use the warranty. Each device is unique. Especially I have seen A LOT of differences with thermal pastes. Amount and quality of it.
3-18 22:49
