DJI Natalia
djiuser_ELViLyNTQUZl Posted at 5-6 07:52
I am having the same problem, my left side mic doesn't charge in the case, so I have to switch the mic's to the right side alternating, so that it charges. AND the TRS orange (output) 3.5mm jack doesn't work... AND The safety track has never worked either.
We apologize for any inconvenience caused. Please ensure that the adapter is correctly installed and there is no gap between the receiver and the charging case. Verify if a mobile phone adapter is connected to the receiver. If it is, remove the adapter and check if the receiver can be charged inside the charging case. If the receiver can be charged inside the charging case, either remove the adapter or ensure it is properly installed. If the charging issue persists, please return the device for further assessment. You may click on this link: https://www.dji.com/global/support/repair |
