What is the correct way to charge DJI Mini 4 Pro?
435 17 3-21 09:36
USER001
I have a question: how do I charge my DJI Mini 4 Pro Intelligent Flight Battery (the Standard Battery)? Do I just pop the battery into the drone and plug a cable into the drone so the power goes through the drone and into the battery, or should I buy one of those DJI charging hubs? Just asking because I'm now unsure after a friend said that with his drone, (the DJI Phantom 2), he says it is best if I use the charging hub, because he says charging the battery through the drone could cause an unstable energy flow, and, in a few years, it could start degrading the battery, and he says that charging hubs are specifically designed to give a stable flow of energy.
3-21 09:36
Serg SSA
Flight distance : 6406329 ft
Russia
The battery can be charged in the drone, this is normal, I do this often. If you have several batteries, then it is better to buy a hub.
3-21 09:50
USER001
Serg SSA Posted at 3-21 09:50
Alright, thanks for the info. I've got three batteries, so maybe I'll get a hub.
3-21 09:57
DJI Diana
Flight distance : 2408 ft
Hi. Thank you for your inquiry. You can charge the DJI Mini 4 Pro Intelligent Flight Battery by mounting it to the aircraft or by charging it via the charging hub. It is recommended that you use the charging device provided by DJI, such as the DJI Mini 3 Pro two-way charging hub, the DJI 30W USB-C charger, or other USB power delivery chargers. For further instructions and details, please refer to https://dl.djicdn.com/downloads/ ... User_Manual_EN.pdf.
3-21 15:13
USER001
DJI Diana Posted at 3-21 15:13
Hi. Thank you for your inquiry. You can charge the DJI Mini 4 Pro Intelligent Flight Battery by mounting it to the aircraft or by charging it via the charging hub. It is recommended that you use the charging device provided by DJI, such as the DJI Mini 3 Pro two-way charging hub, the DJI 30W USB-C charger, or other USB power delivery chargers. For further instructions and details, please refer to https://dl.djicdn.com/downloads/DJI_Mini_4_Pro/20240115/DJI_Mini_4_Pro_User_Manual_EN.pdf.
So is the Mini 3 Pro charging hub also compatible with the Mini 4 Pro?
3-23 10:24
DJI Diana
USER001 Posted at 3-23 10:24
Yes, DJI Mini 3 Pro Two-Way Charging Hub is compatible to use. I hope this clarifies your inquiry.
3-23 14:48
USER001
DJI Diana Posted at 3-23 14:48
Sorry for keeping on asking questions, but will the DJI Mini 3 Pro Two-Way Charging Hub charge an Intelligent Flight Battery or Intelligent Flight Battery Plus made for the DJI Mini 4 Pro the same way a DJI Mini 4 Pro Two-Way Charging Hub will charge it?
3-25 11:24
DJI Diana
USER001 Posted at 3-25 11:24
Hi. Thank you for your response. The DJI Mini 3 Pro Two-Way Charging Hub can charge both the Intelligent Flight Battery and the Intelligent Flight Battery Plus in sequence. Thank you.
3-25 15:54
Montfrooij
Flight distance : 2560453 ft
I just got a 3 way charging hub. It's not 'better' but it's more convenient.
3-26 00:11
USER001
Montfrooij Posted at 3-26 00:11
What's the difference between 2 way and 3 way?
3-26 08:37
Montfrooij
USER001 Posted at 3-26 08:37
There is no 2 way.
3-26 08:44
USER001
Are you sure?
https://store.dji.com/uk/product ... t=58&vid=114201
3-26 08:51
Montfrooij
USER001 Posted at 3-26 08:51
Are you sure?
https://store.dji.com/uk/product/dji-mini-3-pro-two-way-charging-hub?from=search-result-v2&position=1&total_result=58&vid=114201
My bad, there is no 3 way.
I was mistaken the nr of batteries it takes. But that is apparently not the the amount of 'ways' they are talking about.
3-26 08:53
USER001
Montfrooij Posted at 3-26 08:53
I think two ways means that it has two ports: One port to charge itself, and the other port to charge other stuff. BTW this might not be accurate, I'm just making a guess using the information what I already know.
3-26 08:55
Montfrooij
USER001 Posted at 3-26 08:55
You could very well be right. I'll check the store.
Yes, it says 2 way. One for the batteries and one for the remote.
3-26 10:10
USER001
Montfrooij Posted at 3-26 10:10
That makes sense
3-26 10:12
Montfrooij
Yeah, I thought so too.
3-26 10:28
USER001
Dirty Bird Posted at 3-26 17:48
If you have 2 or more batteries a charging hub & 30-watt or more PD charger is the way to go.  The DJI Charging Hub works fine for overnight charging of your Mini 3/Mini 4 batteries.  It charges them sequentially, starting from the one with the most charge to the least.  If all three batteries are @ 0% it requires about 4 hours to fully charge all 3.  This is a good overnight charging solution.
I don't know how much or often you fly.  If you fly often or want your batteries ready faster than 4 hours, consider one of the multi-charger options.  My personal favorite is the Hanatora LCD Charger.  This charger concurrently charges 4 Mini 3/Mini4 batteries, along with your RC & cell phone.  It takes about 90-110 minutes to fully charge 4 batteries, RC, & phone from 0% to full.  It also offers a very nice LCD status display, as well as a Storage Charge setting.  It is quite reasonably priced at around $57 US.
Cool gadget, very useful for people who fly a lot, but I think the DJI Two-Way Charging Hub is enough for me. https://store.dji.com/uk/product ... ging-hub?vid=114201
3-29 02:19
