DJI Thor
Flight distance : 13602 ft
Thank you for your reply. We mainly need to vary it into two aspects, one is the interference of the external environment, the other is the mobile device performance or connection itself, which means internal factor. So you can try to fly in another place, adjust the antennas of the RC, make sure the remote controller’s antennas are positioned parallel to and are pointed towards the aircraft; then you need to check if there is a bad connection between the RC and your mobile device, try another mobile device, use a mobile device with a strong performance and see if it works.
If the issue still persists after trying, it is suggested to send back the device to our service center for a product inspection. You could register a case via the following link, https://repair.dji.com/, thanks. |
