Waypoint mission and height
199 3 3-25 05:43
djiuser_SwgXPHgTqxAj
Poland
Hi All,
I have a question regarding mission flight in Mini4Pro. When I create a mission either manually or marking waypoints during the flight, the corresponding height is recorded. Is that the same height that is raported on the telemetry on the screen? When I run the same missions from two different spots (different evelation, for example form 300 and 350 AMSL), will the flight path be the same, or elevated by 50 meters? Thanks
3-25 05:43
Serg SSA
Flight distance : 6406329 ft
Russia
The height of mission points is measured from the height of the starting point. The next time you perform a mission from a different point, you will need to make adjustments to the height of the points. It would be nice if DJI made all points automatically adjust to the value you enter manually, so you don't have to go through all the points.
3-25 07:17
Poland
As I assumed then Thanks guys for clarification
3-25 09:20
DJI Tony
Hi there. Indeed, the flight height of an aircraft is determined relative to the ground from which it initiates takeoff. Have a nice day.
3-26 01:12
