Advanced gimbal adjustments
300 3 3-26 09:20
fansebc1ce0e
Hi,
I have a Mavic 3 Classic that tells me the firmware is up to date.
Watching videos on You Tube about how to adjust the gimbal for smoothness they talk about 'advanced gimbal adjustments' in the Control section.
My Mavic doesn't have this. Am I missing something, how can I get it? Has it been removed in some update?
Thanks for your advice.
Ron
3-26 09:20
DJI Gamora
Hi, Ron. Thank you for reaching out. The DJI Mavic 3 Classic has indeed the Gain & Expo Tuning under the Control Settings. Can you please confirm which Remote Controller and application you have with your Mavic 3 Classic?
3-26 21:51
fansebc1ce0e
Hi, I have the RC Pro with my Mavic 3 Classic and that has the Gain and Expo settings. I have seen an extra setting ‘Advanced Gimbal Adjustments’ used in You Tube channels which I do not have. I don’t know which application you refer to, as far as I know it’s the DJI standard app?
3-26 22:25
DJI Paladin
Flight distance : 318 ft
fansebc1ce0e Posted at 3-26 22:25
Hi there. Thank you for keeping us posted. To access the Gimbal Advanced Settings, you need to go to Gain&Expo Tuning then scroll down to check with the Gimbal advanced settings which you can select the "Max Control Speed (Tilt) and Tilt Smoothness. You may refer to the image below. Hope this helps.
3-27 21:52
