chrisduke
Last weekend I flew my Phantom 3 Professional and crashed it, but it was out of my control. Here's what happened, and is now happening.
1. Flew it 8/29 on several missions, and had zero incidents.
2. I didn't do anything to it but charge the batteries.
3. Flew it the following weekend on 9/5 and after using the controller to fly it straight up, it started going away from me to my right. I took my hands off the sticks to make sure it wasn't me accidentally, and it just kept going. I was able to fly it down a bit and closer to me, but then it just made a b-line for some trees, then crashed to the ground right next to a car. Thankfully, it avoided the car. I had no control of the aircraft like I normally do.
Visible damage:
- Props turned a little green from the tree.
- One of the (what appears to be an) attenae that ends in a plastic piece and pops into the landing gear had popped out. I popped it back in.
- Some slight scratches to the side of the camera. Somehow it hit something.
- Two of the anti drop clip pins popped out from the Camera Vibration Absorbing Board. I put new ones in that were included in the accessory kit (and have since ordered more)
From what I recall, it fell straight--props down. It happened so fast, and I was so confused about what was happening, it may have fallen another way though. I basically lifted up off the ground, it flew up and over some trees... I was able to fly it back toward me, lower it back down a bit, and then it went right back to those trees and instead of going over them, went right into them.
I haven't flown it since last weekend. Today I upgraded the firmware to Phantom 3 Professional Firmware v1.4.0010
So what's wrong now?
1. It won't calibrate. I get the error after I perform the two horizontal and vertical position turns that there's magnetic interference and it won't re-calibrate. I've tried it several times in several different areas.
2. When I move the aircraft around by hand, the stabilization is still smooth, but it gets twitchy. Here's a test video I recorded inside, but it does the same thing outside: https://www.dropbox.com/s/d4c431l0juqmxgq/DJI_camera.mp4
Any ideas? The camera seems fine (the image recorded and sent to the controller), so maybe the gimbal got jacked?
Thanks for your help!
