Auto-Calibrate Gimbal Every Flight!? HELP!
3086 11 2015-9-12
jtmatchett
Does anyone calibrate their gimbal before each flight? I noticed after the latest firmware that the horizon is not level again. I got out my level and placed my Phantom on the most level surface in my house. I did an Auto-Calibration and it did fix the horizon level issue. BUT, when I turned the Phantom off and then back on, the horizon was not level again. Anyone else notice this?
2015-9-12
pi-inthesky
Flight distance : 13058 ft
your thread saved me asking the same question cant remedy the problem myself but don't worry we wont have to wait long before some of the guys respond come on sploodge, raykoni, redhotpoker, williewonka to name but a few who are worth listening to
2015-9-12
gHiDoRa
no i dont do thr gimbal caliration everytime and yes i still had titled problem but not really bad, im just normal flyer so no big deal. Anyway did u tried to do the IMU caliration yet?
2015-9-12
jtmatchett
I have not tried an IMU calibration yet. Not sure that will actually fix it. No other issues other than the tilted horizon level.
2015-9-13
danieldos22
Yes you have each flight calibrate
2015-9-13
gHiDoRa
jtmatchett Posted at 2015-9-13 21:23
I have not tried an IMU calibration yet. Not sure that will actually fix it. No other issues other t ...
yes IMU caliration could fix yr titled video problem, made sure do gimbal calibration right after IMU calibtation.
2015-9-13
rayrokni
Flight distance : 8139875 ft
make sure you do a COLD IMU calibration, so u dont have to wait when u turn on p3 for the imu warming up sign.
http://forum.dji.com/thread-27393-1-1.html
2015-9-13
jtmatchett
Ok, I just calibrated the IMU for the first time and auto-calibrated the gimbal afterwards. WOO HOO!! Fixed my issue! To confirm it was fixed, I powered down the Phantom and then powered it back on and horizon was still level. No need to re-calibrate every time! Thank you all for your help!
2015-9-13
bahamasboy
Flight distance : 13845 ft
jtmatchett Posted at 2015-9-13 17:07
Ok, I just calibrated the IMU for the first time and auto-calibrated the gimbal afterwards. WOO HOO! ...
The horizon in your pic is not level.  Was this a before or after?   That amount of tilt drives me batty... I have to combat it every flight as well.   Even after auto calibrating while in a solid hover, it goes in and out of level.    At least we're not alone in these problems.!
2015-9-13
jtmatchett
bahamasboy@aol. Posted at 2015-9-13 18:12
The horizon in your pic is not level.  Was this a before or after?   That amount of tilt drives me ...
This was after IMU calibration. You should have seen it before. It was pretty windy when I took this so I'm sure thats having some effect on it. When I had the Phantom at lower altitudes the horizon level was fine..
2015-9-14
rayrokni
danieldos22@hot Posted at 2015-9-13 22:16
no u dont need to do imu calibration b4 each flight, absolutely you dont
2015-9-14
gHiDoRa
good to hear it fixed your problem.
2015-9-14
