JJB*
Flight distance : 12516775 ft
Tuxtard Posted at 4-3 21:29
Hello JJB,
Thank you for your analysis. If you can, please take a look at the flight log from the post #1. There were multiple occurrences of this issue during that flight and I was using the Plus battery. For example, here is another extract from that log that shows more than 10 seconds of same pattern oscillations starting from the second 360, where pitch angle goes down to -38.
Hi Tuxard
Chart 1 - 4, your 4 time slots.
Few 'things' in flight with effect on drone pitch changes.
- Yaw input flying with speed
- OA sensing false Obstacles
- IR height measuring yes/no height with OA sensing on/off
- Combination of these
Not a explanation for pitch oscillating, bit guess it can be a trigger to start or make it worse...
Chart1 - IR height measuring On/Off + yaw input
Chart2 - IR height measuring On/Off
Chart3 - No idea, but not much oscillating
Chart4 - Hard to tell, 4 direction RC input.
Mayby DJI can look again and better into this.
I had a flight the other day with my Mini4Pro, flying away from my position (watching the drone), i stopped the forward speed as the drone was fluctuating and i could hear the rpm fluctuating as well. Checked now my log, see the result in my chart. 2x pitch oscillating ! After this a perfect flight.
Will check my next flights to see if it happens again in certain flight situations.
cheers
- JJB [ Charts by FRAP ; the 'best' software for data and visual flightlog analysis (www.jjbfrap.eu) ]
