Speed on the avata 2
1978 25 4-11 05:55
Marclykke76
Flight distance : 589331 ft
Denmark
As i can read the speed on the avata 2 is  slight bit faster than the old avata. And also with the motion controller. But is says that there is a limit on it with 19 m/s in Europe ??? is that locked or can you disable that limit ????
4-11 05:55
DAFlys
I bet thats locked as its an EASA requirement for C marked drones.
4-11 06:04
DJI Paladin
Flight distance : 318 ft
Hi there. Thank you for reaching out. We will coordinate this to our relevant team for further clarification. We will respond to you in a timely manner. We appreciate your patience.
4-11 21:05
LV_Forestry
Flight distance : 4726654 ft
Latvia
This is a prerequisite for obtaining the C1 label.
It is irrevocable unless a declassification process is put in place.
4-11 21:11
Benjamin Senf
Flight distance : 483448 ft
You want to know something even „funnier“? They state on the spec sheet, that the maximum speed in sport mode is 16 m/s. Thats 57,6 km/h. Only in MANUAL MODE you can obtain the joke speed of 19 m/s (68,4 km/h). And you can only get into MANUAL MODE with the fpv rc 3 and NOT with the motion rc 3. So to summ it up: You need to buy the fpv rc 3 for an EXTRA 149€ to fly an FPV DRONE at maximum speed of 68 km/h compared to the speed of 27 m/s (97,2 km/h) OUTSIDE of the f*cking EU. Its just pure madness with these drone regulations in the EU. Why THE F I should buy a FPV Drone to fly this god damn slow?!
4-11 23:09
djiuser_b2FdCqjTjHov
How does the drone perform jn the air tho ... in a dive for example.. does the drone just pulls its nose up when it becomes too fast ?
4-11 23:12
LV_Forestry
Latvia
Benjamin Senf Posted at 4-11 23:09
You will thank everyone who asked for a C1 label without knowing what it was about.
4-11 23:14
axgrf
Flight distance : 101276 ft
How do they even want to enforce that in M-Mode? The drone cant just hit the brakes when diving???
4-11 23:15
LV_Forestry
Latvia
axgrf Posted at 4-11 23:15
The law imposes 19m/s in "level flight", therefore in diving the only limit is indicated by the mass of the drone and its energy at impact which are regulated. Which are obviously correct since it received certification.
4-11 23:19
Marclykke76
Denmark
Yeah, i dont get why you cant get full speed with the motion controller. Its no less safe to fly with that. The last 3 m/s you also get with that. You should be able to set the speeds as you want them as you can in the m4p.
And then those lawmakers should stop putting so many forced rules up. Cars can also drive faster than they are allowed to. Make speed limits and trust people to keep them. Give them a fine if they dont.
4-12 00:17
Depp
Flight distance : 1868796 ft
The difference between S and M is not only the slight speed advantage but the full control over the drone.
The low speed is because of Europe's C1. I guess one could "unlock" it but then it wouldn't be C1 anymore...
4-12 03:07
Fozando
Flight distance : 682438 ft
Then it's official. It is impossible to go over 19m/s even if you are flying under the A3 subcathegory...
I can't understand how it is not possible to activate that speed limitation only when you are under the A1 subcathegory and fly without limitation in the rest of situations.
This time it is not DJI's fault, it is from EASA and other authorities brilliant minds...
4-12 04:45
The speed limit is for sure .... but how does this affect the acro mode? For example ins a dive or so? Will the drone just pull its nose up?
4-12 09:32
The Saint
Flight distance : 5902228 ft
Marclykke76 Posted at 4-12 00:17
Don't know about in your country but in America, there is no roster for "drone violations."  Any and every rule or regulation you break could lead to a fine up to X years in jail or $XX,XXX fine.  Of course it never happens but it's designed that way for two reasons.  With such a harsh penalty hanging over your head for even the simplest violation, the offender will likely always plea to whatever lesser punishment is offered.  This means the FAA decides the punishment and you accept it and the FAA never has to go to court to defend anything.  It also means no one will think about breaking the rules or regulation because you could be arrested even though you likely will not.  People aren't perfect so they're still going to break the law which means when you are caught or accused, you are more likely to be submissive.
Think of traffic violations.  If you were speeding or running a stop sign and when caught, you got arrested and could go to prison (instead of thinking you'll just go ahead and take the risk and pay the small fine if caught)....there would be no traffic court.  That's why there are hundreds if not thousands of traffic violations per day; not because the lack of enforcement but mostly because the fines are set and people establish and accept the risks.  Drone pilots won't be given such a "out" likely because of the near zero enforcement.  You fly too fast or too far or over someone's head and it's bad bad bad for you if you are caught so don't do it.
4-12 14:38
Marclykke76
Denmark
The Saint Posted at 4-12 14:38
first of all the speed limit is for europe only, so not really sure why you bring up the US. Anyway, the point was that user should not have a limiter on their device. You should be trusted to not break the law. Just as you are with a car, that can drive faster than the speedlimit ;-)
4-14 04:54
djiuser_sYPBhgtpTGwQ
China
Marclykke76 Posted at 4-14 04:54
You reminded lawmakers to set speed limiter on cars. They'll find that: Can a drone have a limiter, why can't a car?
4-14 19:56
Will_Jachar
Flight distance : 215594 ft
Czechia
I don't get it. Isn't the FCC hack (the ham file) also technically breaking the EU legislation (as it bumps the transmitting power way above EU limits)? Any yet it's still an "official" hack. Why can't they do the same thing with the speed. Limited out of the box but leave a "bug" in the system so we can unlock it ourselves?
UPDATE:
Nevermind. FCC hack doesn't work in the EU either: https://www.youtube.com/watch?v=uKvIkMoU7I8
4-14 23:35
djiuser_Ys3r6DZBbVzj
Flight distance : 117326 ft
Bulgaria
DJI Paladin Posted at 4-11 21:05
Hey, thanks for your help, did you manage to find an answer yet? Sorry if so, but I cant seem to find it.
4-16 13:20
DJI Paladin
Thank you for patiently waiting. This function is required by the EU regulations. You may find it on the EASA website or click the link below. We appreciate your understanding.
https://eur-lex.europa.eu/legal- ... =CELEX%3A32019R0945
4-17 23:40
djiuser_lQg8W6C3rO9p
What if you buy the Avata 2 in Europe and you use it out of Europe? Is still speed limited or it’s unlocked due to geolocation ?
4-30 13:44
eXrevo
Flight distance : 52510 ft
Switzerland
djiuser_lQg8W6C3rO9p Posted at 4-30 13:44
Every country may have different regulations. It's not only about EU or not. But yes, if the country allows using FCC mode, it will automatically switch to FCC and use it instead of CE.
5-9 07:48
fichek
Flight distance : 954216 ft
Croatia
eXrevo Posted at 5-9 07:48
True, it's not all of Europe, it's EASA member states which includes EEA + Switzerland. That leaves many countries that use CE mode for RF, but don't have the 19m/s limit (and EASA C1 label is meaningless there anyway).
Both the RF mode (FCC/CE/SRRC/MIC) and the presence of speed limit are geolocation-based, so traveling with Avata 2 (or any other DJI drone) will affect those.
5-9 13:19
DJI Paladin
Hi there. Thank you for reaching out. The manual mode restriction (no faster than 19 m/s) is only applicable in the EU region. If you are flying your drone in a different country outside the EU, please refer to the Max Horizontal Speed in the DJI Avata Specification on our website. Should you have other inquiries, feel free to contact us.
5-9 22:44
djiuser_Q7aDkXPqTA7J
Lithuania
Please, we all request to unlock speed limit for S mode!!!! 16 is just a joke!!!!
5-10 15:21
FPV1213
Flight distance : 8730 ft
Turkey
There is a limit and you can set the speed limit in the settings and fly as fast as 30ms.
5-11 05:49
fichek
Croatia
FPV1213 Posted at 5-11 05:49
We're talking about Avata 2 here, not DJI FPV.
5-12 05:39
