Luca Rubino
Flight distance : 711512 ft
Mr. Mucus Posted at 4-13 10:41
It is not "$128 for prop guards". It is $128 for ANYTHING. If it gets run over by a semi, you can gather up the pieces & get a replacement. If it crashes in the ocean, as long as you can retrieve it, you get a replacement. And you can do that up to FOUR times over 2 years for $29 per incident. Even if you lose it completely, you can get a replacement, though the deductible is higher.
For your level of experience & choice of equipment, perhaps the Avata/Avata 2 is not optimal, but keep in mind the Avata & Avata 2 are what I will call easy FPV. No need to build a quad, spend hours learning & tweaking in BetaFlight, or to assemble an FPV kit. The Avata kits allow people to easily enter the hobby, which is good for all of us who enjoy RC. Newbies can immediately enjoy flying in Normal or Sport modes, then move up to Manual mode if they so desire. Care Refresh makes perfect sense for these users.
Yes but if a just brake the props guard, I pay still 128 euro!
Other than the VTX (and not all vix in the market), which part in a FPV drone cost more than 128 euro nowadays?
Also the O3 camera cost 99 dollars if you accidentally brake it (never happened to me). Less than 128 dollars.
It is not 29$ for one incident. Did you forget about the 99 dollars? It's at least 78 dollars.
I won't buy the Avata 2. It doesn't suite my needs. But it's not the point of the thread. Because the Avata 1, as you said, could be great for newbie, but it's reparable. Easily.
And another thing people don't consider, sometimes you need to disassembly your drone to clean it. If accidentally you land it on the sand. If you crash over some mud. There are a lot of cases. And one of them happened to my (ex) Avata 1. I removed the props guard, the cage and cleaned everything and it was again like a new ones. Impossible to do without remove at least the props guard.
Now you have to spend 29 (78) dollars for that?
Avata is a FPV drone. Not a Mavic. Crash, incident and pilot errors are not rare. Even to super Pros pilots. Thinks about a newbie
