Smart Controller AIR2S C1
307 8 4-13 05:46
djiuser_JBt7b8vwAlXV
Flight distance : 353041 ft
How is the C1 certification activated with the SC???
Thank you
4-13 05:46
Fozando
Flight distance : 818248 ft
Install the DJI Fly  on your smartphone and send the photographs with the labels on your drone
4-13 06:53
DJI Tony
Hi there. Thank you for reaching out. The screen-equipped remote control does not support image uploads. As Fozando advised, kindly use the DJI Fly app on your mobile device or DJI Service Portal for image uploads instead.
Your final document will appear in the Fly app-service-Cx label Request or login DJI Service Portal within 3 working days. Through the whole application process, you can trace the application progress via the DJI Service Portal. Feel free to contact us if you have any further questions. Have a great day ahead.
4-13 22:13
DosPalotes
Flight distance : 39820 ft
DJI Tony Posted at 4-13 22:13
But to use the Fly App you need a RC-N1 controller since you need to be connected to the drone somehow .
4-15 01:50
Fozando
DosPalotes Posted at 4-15 01:50
Then transfer the photographs usign a SD card from your phone to the DJI RC and once you have the connection to the drone, I think that you can do the process without issues.
4-15 02:22
DJI Tony
Hi there. If you are using an RC-N1 there would be no problem since you can take a photo using your phone and upload the photos directly to the Fly app.
4-15 03:59
DosPalotes
Fozando Posted at 4-15 02:22
This is a very good idea, thanks mate.
4-15 05:16
DosPalotes
DJI Tony Posted at 4-15 03:59
Hello Tony, thanks for your reply but i am NOT using a RC-N1, this is the problem. I can install the Fly App on my smartphone but i need to be connected to the drone to start or work on the cx-process in the app. But the solution Fozando told me should work, taking photos with the phone and copy them to the SD card in the RC controller. So it should be possible to upload the pictures in the RC or not?
What is the issue with the RC controller and the photos? That it is not able to take pictures and photos or is there any other problem which makes it impossible to upload photos, even if they are saved on the SD Card?
Ok no problem, Tony added the link to where to upload the photos into the service area. Thanks Tony
https://repair.dji.com/certification/list
4-15 05:19
DJI Tony
DosPalotes Posted at 4-15 05:19
Perfect. I'm glad you already got it sorted out. Please keep us posted if you have further concerns. Have a nice day.
4-16 03:04
