"Moisture detected" warning on Samsung phone when connecting goggles
224 6 4-13 09:33
fansa4e9a5ba
Flight distance : 24081 ft
If you encounter a “Moisture Detected” warning on your Samsung Galaxy phone when connecting it to your DJI Avata goggles, you may try keeping the cable connected and then force-restarting your phone. This can clear temporary bugs causing the moisture warning.
4-13 09:33
DJI Paladin
Flight distance : 318 ft
Hi there. Thank you for reaching out. We're glad that you have managed to isolate the issue that you experienced and share with us the ways how you fixed it. However, could you please provide us a screenshot showing this error message so we can forward it to our relevant team for further clarification? We would appreciate your input. Please keep us posted.
4-13 20:50
fansa4e9a5ba
DJI Paladin Posted at 4-13 20:50
I have confirmed that this error is caused by the DJI app and goggles - not the cable.
1) disconnecting the goggles and then restarting the phone corrects the error.
2) I tried several different cables and I get the the error regardless which cable I use.
3) I have two batteries for the goggles. swapping the batteries doesn't fix the error.
4) as long as the DJI app is not running then I do not get the error.
5) and finally, by fiddling around with the goggles and the app and restarting the phone a few times I am able to get rid of the error and fly the drone.
Have you seen this or had reports of it and what would be causing the issue?
4-29 12:58
fichek
Flight distance : 1100308 ft
Croatia
I think it's a common issue with Samsung phones. A friend of mine gets that error every time he uses my USB-C charging cable (genuine Google cable from a Pixel phone) that has never been anywhere close to moist (and some of the devices I use with it also have moisture detection and never triggered on that same cable).
4-29 13:31
DJI Paladin
fansa4e9a5ba Posted at 4-29 12:58
[view_image]
Hi there. We appreciate your response. If you experience this issue, kindly check the mobile phone port and smartphone adapter for any foreign materials. Wipe the smartphone adapter with isopropyl alcohol and try connecting again. Also, you can use a different USB-C communication cable to connect to further isolate the issue. You can use a different mobile device iOS/Android and try to check if you still experience the problem. Please keep us posted.
5-2 20:54
fansa4e9a5ba
DJI Paladin Posted at 5-2 20:54
DO YOU UNDERSTAND?
5-23 12:06
DJI Paladin
fansa4e9a5ba Posted at 5-23 12:06
Thank you for keeping us posted. We're glad that you have managed to isolate the issue and share with us the steps that you have taken to fix it. If you have other inquiries, feel free to contact us. Thank you for your valued support.
5-23 21:40
