No RID on Mavic 2 pro
287 6 4-14 09:33
Paul_
Flight distance : 4472 ft
I am using a Mavic 2 pro with original controller RC1B, a crystal sky, and a Samsung S22 as a hot spot. There is no indication of RID being transmitted on available wifi sites.
Mavic 2 pro   v01.00.0797
RC v01.00.0770
Crystal Sky  v03.00.03.00
DJI GO 4.0  v4.3.60
Anyone with any pointers??
Paul
4-14 09:33
DJI Tony
Hi there, Paul_. It is recommended to test in an open outdoor area with a strong GPS signal and ensure to avoid testing indoors or in a closed space. A weak GPS signal will cause the RID to be unable to broadcast normally. Have a nice day.
4-14 19:15
Paul_
I have tried several times, all outdoors and all with strong signals showing 14  satellites. And, the CrystalSky connected to the hot spot. On start up Go 4 is showing, version check, collecting device info, comparing,with server, latest version before go fly.
4-15 03:52
Paul_
No response from DJI?????????????
4-23 09:22
Mobilehomer
Flight distance : 18150351 ft
Using the S22 as a hotspot turns the wifi off. Try checking with the HS off.
4-23 10:51
Paul_
Mobilehomer,
Duh      It gives me a warm feeling of encouragement that age has not diminished my ability to misplace my mind.
Many thanks!!  All is well.
Paul
4-23 12:39
DJI Diana
Flight distance : 2408 ft
Paul_ Posted at 4-23 09:22
Hi Paul_, we are very sorry for the delayed response. We understand that you already tested in an open outdoor area with a strong GPS signal, and the aircraft firmware has been upgraded to a version that supports FAA Remote ID (Mavic 2: V01.00.0797). If the issue still persists, please collect the following information and send it to us: screenshots of the app (about page) showing the version information, app logs, aircraft logs, and test time. Alternatively, you can contact our DJI support and send the information at https://www.dji.com/global/support?site=brandsite&from=nav for immediate assistance. Thank you for your understanding and cooperation.
4-23 15:15
