stvnvicbc
Personally, i would do a compass dance on shore first if you haven't flown in the area previously.
If you are going to be alone, i would not recommend hand launching or catching although i HAVE seen it done Sector. My recommendation would be to set the P3 on the deck of the boat (or another flat surface) and take off from there. Land it the same way if possible.
If you have a lanyard or harness for your RC then the hand catch isn't so difficult, but be advised that if the P3 tips towards your arm when you are in the process of killing the motors it will most likely bite you. As for launch i'm guessing most people use the auto take off button while holding the drone upright but i've never tried it. |
