How bad is the lowlight quality on the dji o3 air unit?
196 2 4-25 11:59
Potato mini
Flight distance : 7275348 ft
thanks for the time
4-25 11:59
fichek
Flight distance : 984478 ft
Croatia
Not terrible, not great. Better than Action 2, worse than Action 4/Avata 2. If there's for example street lights, you can make it useable, especially if you go down to 60fps (you could go 30 but that's just not worth it as it's too hard to fly in a slideshow imo).
Here's an example of me flying in a dark-ish abandoned building with an ND8 (since I flew outside too and there was still a decent amount of daylight outside) at 120 FPS (go to about 1:05 in the video to switch to O3AU footage, before that is Action 2 at 4k30, 1/60 shutter and also with ND8). It's a bit grainy, but you could reduce that by losing ND filter and using some post-processing. There's no noise reduction in post on this video and iirc I also turned down the onboard noise reduction by 1 or 2 points in advanced camera settings.
Of course, if you don't care about the recorded video, but only want to know how well it does for flying in low light - I'd say with auto iso limit set to max possible value, it still looks better than any non-starlight analog camera
4-25 14:19
Potato mini
fichek Posted at 4-25 14:19
Thanks for the input. very helpful. It looks like it's not as bad is i though, which is nice. haha yes much better than any analog by far.
4-26 09:02
