air 3
702 1 2024-4-25
gopher1
Flight distance : 293898 ft
hi a bit stuck here
with the battery in arib 3 push the power button for but long all led tuernd yellow and case a long  ie 1234 1234 ect
only to stop was to remove battery replaced battery now ok thoughts
thanks
2024-4-25
DJI Gamora
Hi, gopher1. Are you trying to turn on the aircraft? If yes, please press the power button once, then press it again and hold for about two seconds to power on the aircraft. You may also check this video for reference:
2024-4-25
