1st Crash and ??s
205 3 4-25 15:05
OldGuy2024
Flight distance : 408855 ft
Crash was due to pilot error.  Trail flying. 7 batteries without anything close to an incident.  I think the rates are at max for S mode.  Saw a gap in the tree canopy and tried too shoot through it. Next time I think I'll approach such "gaps" very slowly.  Must of clipped a tiny branch. Avata2(A2) went tumbling down to earth from ~10 meters landing on a soft surface covered in leaves. At least I got to try out the "Find My Drone" feature and finally sync the drone to the app. Only damage was port side front propeller needing replacement. Chunk of one blade was missing.
Have the unit set for "Auto" channel selection.  Assuming the "better" choice for maintaining the most solid connections?
Anyone know based on the original Avata how many hours before the stress of flying fatigue the propellers?
Need to set the RTH altitude at 90 meters to clear the taller trees uphill from the launch pad.  Pucker moment while finishing off the last battery trail flying. 1km short. Low battery RTH kicked in. Didn't want to sky into another tree.  Hit the lock button.  Not sure if I held it or just tapped it couple times.  Auto landing kicked in.  Relief.  Time to go read another section of the User's Manual.
Have a real issue trying to fly over my neighbors orchard. Go from 60 to <10 Mbs of strength in a blink.  Almost like a wall of interference when above the treeline.  Today, dipped below the treeline before hitting the weak signal wall.  Strength  dropped due to trees, but stayed in the teens.  Mystified why.  Flying N of my 40 there is another section that the signal strenght drops rapidly, but not into the critical Red and not as sudden.  Reminds me of the hidden fences used to contain pet dogs.
4-25 15:05
DJI Gamora
Hi, OldGuy2024. Thank you for reaching out and we're sorry to read about what happened. Since the drone crashed, we highly recommend that you send your drone back (even if there are no errors) to us for further diagnosis. You may also request a data analysis to check on what happened (a fee might be applied). You may submit an online repair request through this link: {https://repair.dji.com/repair/index}. If you need assistance with creating a ticket, you may contact DJI support at (https://www.dji.com/support). Thank you
4-25 19:25
OldGuy2024
DJI Gamora Posted at 4-25 19:25
No issues with the drone. Flew fine with the  remaining capacity of the battery plus one more after replacing the broken propeller. Later that day. A short session before sunset.  Only had good light for one battery.  The A2 flew like new.  Tough little drone.
4-26 13:26
DJI Gamora
OldGuy2024 Posted at 4-26 13:26
Glad to hear that, OldGuy2024. In case you want to have it diagnosed, please refer to the links provided above. Have a safe flight!
4-29 08:30
