RS4 Pro focus motor calibration issue
246 4 4-27 04:07
urbie
Flight distance : 2006224 ft
Hello.
I use a Canon EOS R10 RF-S18-45mm F4.5-6.3 is STM with my RS4 Pro. The teeth on the motor are more coarse than the teeth on the lens. The calibration feature doesn't work because the motor gear teeth doesn't mesh well with what's on the lens. The motor continues to spin after the lens has reached its mechanical stop. Is there a way to decrease the motor torque or to exchange the motor gear with one that has finer teeth?
I am able to calibrate the motor manually, though.
Thank you.
4-27 04:07
DJI Wanda
Hello, there. Sorry for the inconvenience. We will consult your issue with our engineers first.
4-27 04:55
DJI Wanda
Update: Our engineers recommend you use Focus Gear Strip to make it smoother.
4-29 01:44
urbie
DJI Wanda Posted at 4-29 01:44
It worked! Thank you.
4-29 11:03
DJI Wanda
urbie Posted at 4-29 11:03
You are most welcome.
4-30 00:39
