DJI Wanda
![](https://forum44.djicdn.com/data/attachment/common/c4/common_1_usergroup_icon.png) Administrator
Hello, there. You may check the information below and see whether your setup is right:
DJI RS 4 Pro supports controlling up to two focus motors.
When dual-focus motors are installed, the motor can be controlled by the front dial. Make sure “Dial Functions” is set to “Focus Motor” and the Joystick Mode Switch is toggled to Zoom. At this point, both focus motors can be controlled for focus and zoom.
When the focus motor controlled by the joystick is connected to the lens aperture ring, the lens aperture can also be controlled. In this case, no additional settings are required for the joystick.
