Sean-bumble-bee
Flight distance : 15997 ft
From memory that screw is weird.
If I am correct it has two distinct threads, the larger diameter thread is the one closest to the head of the screw.
Both threads are, I think, machine screw threads which struck as odd since the larger thread engages in the plastic of the arm.
The driving slot/hole is "Torx".
As there is only one screw per arm it is ESSENTIAL. From memory it keeps the arm on the actual pivot and with out the screw the arm can be pulled off the pivot.
Remove the screw from the other arm and have a look at it with a magnifying glass, then of course refit that screw, and check whether or not my memory is correct.
I would also have a look in the drone's bag to see if the screw is in the bag, do this over a clean white surface.
You might be able to find the screw as part of a screw-kit, on the likes of eBay, but examine the photos of the kit very closely, to see if the kit contains the screws.
Alternatively
a) buy a wrecked drone or an ex display drone and scavenge a screw from that or
b) see if a repairer, other than DJI, will sell you a screw.
I doubt that DJI will sell you a screw but you could ask. |
