Kayak course at Lee Valley day 1
12Next >
1602 43 5-7 17:36
Bashy
Flight distance : 2354357 ft
Day 1 of my Developing White Water course at Lee Valley on the Legacy run.
The course is 4 weeks long, and every Saturday for 90 minutes.
I know what I should be doing but getting this boat to do that leaves a lot to be desired.
I'm hoping next week will be better as i have gone over the video so many times during editing
that it should now be ingrained into my brain, hopefully!
I'm wondering if it would be better with freeze frames for the on-screen captions, or used voice-overs
with freeze frames for next time, any thoughts, please?
There's one cut that I messed up and I couldn't be asked to rectify, I mean, at such a late stage (6hrs in)
picking up on it on the 4th final run-through, I'm done with it,  I'm hoping the viewer will blink and miss it ;)
or they would have had I not pointed the edit out in the video lol. Anyhoo, enough waffling, here's the finished video.
Action 4 - 1080/60 upscaled to 4k - RS
5-7 17:36
Bashy
Dammit, i need to sort out some bad words still lol and the captions don't stay on-screen long enough, here goes another day encoding and uploading
OK, its back up again but YT still doing its HQ fiddling still
5-7 17:50
DAFlys
Bashy Posted at 5-7 17:50
What happened Bashy?
5-7 23:33
Codgerzh2
Flight distance : 22977418 ft
Looks like you had an amazing day - brilliant
5-8 04:41
Bashy
DAFlys Posted at 5-7 23:33
It was a plss poor edit, when i read the captions back i don't need as long because i already knew what it said, for a new viewer it would take longer and some are still too short, plus i left some swearing in lol
5-8 06:17
Bashy
Codgerzh2 Posted at 5-8 04:41
Thanks and yeah, it was a great day, nice weather too, looks the same for this Saturday as well, so there's that
5-8 06:18
DowntownRDB
Flight distance : 1722 ft
Seems like sweep stroke is super important.  Nice job after the coach left to check on the guy that went into the water.  It seems that timing is really critical there also.  Keep at it Bashy I have faith you'll get better with each attempt and every practice.  No doubt that is not the easiest thing to do or everybody would be trying it.
5-8 13:08
Bashy
DowntownRDB Posted at 5-8 13:08
Thanks chap and yeah, the sweep is quite an important one to learn, and i thought i had a good one
I think what was killing the stroke for me was that my boat was already pointing at the bank, and all i could do was to stop it from turning downstream. Once I get the angle right when entering the flow (1pm'ish) then the sweep should work and then with me looking downstream it will turn and point the boat downstream. Angle and timing!
By rights, i should be able to get from one side to the other in 3 to 5 strokes and with no reactive strokes.
By the time matey took a swim, I'd done a good few runs up til then and I felt that there was a little improvement as the hour had progressed so by the time the coach left I felt a little more confident and without his eyes on me, I felt less pressure.
My only goal is to pass the assessment and to be able to paddle there when I want, 3 more lessons to go, as it stands, I'm not hopeful but with that said, they do not assess at the end of the course, I will have to waste another £40 in fuel +  just to go back for 10 to 20 mins for the assessment , that's another £10. The 25th is when i complete the course and that same day i am hoping to go to another WW center, its no where near as good, its half as wide and only class 2 at most but it can only help towards the assessment at Lee Valley
To be able to do the intro to white water, you only really need to have confidence in undoing the spray deck underwater and getting out of the boat safely. Heck, ya don't even need to know how to swim, with that said, if the coach didn't think you were experienced enough at the start of the course, they would tell you and put you on the preceding course.
Again, thanks, I'm sure it will fall into place, be it this year or in the next 5 lol
5-8 20:00
Bashy
Sorry, i just want to point out one other thing, all of the videos i have watched say to do a sweep when exiting to the flow too so it had been something i had practised, but on the course they say not to do that, you drive across the eddy line and then do what you need to do to turn or stop. I have to change my mindset there as well
5-8 20:04
DAFlys
Bashy Posted at 5-8 06:17
oops.
5-8 21:35
DAFlys
Looks hard bashy and a good job you can swim.
5-8 21:47
Bashy
DAFlys Posted at 5-8 21:47
To be fair, i probably make it look harder than it is lol
Believe it or not, knowing how to swim is not a prerequisite, you have a PFD (buoyancy aid) and there are staff strategically placed with throw ropes or will jump in if you are in trouble. It is probably a lot safer than it looks
5-8 22:09
DAFlys
Bashy Posted at 5-8 22:09
I noticed the guy on the side with a hard hat,  I assume he's for safety?
5-8 23:43
Bashy
DAFlys Posted at 5-8 23:43
Yes chap, I would say there's at least 4 for the 160m (1.6m drop) of the Legacy course, and maybe even more on the Olympic course, that's hella steep at 5.5m drop and 300m long
5-8 23:50
DAFlys
Bashy Posted at 5-8 23:50
I guess thats what makes these courses so expensive.
5-8 23:59
Bashy
DAFlys Posted at 5-8 23:59
Yeah, true, corporate events go a long way to cover costs etc too
5-9 00:21
DowntownRDB
Bashy Posted at 5-8 20:00
Sounds like in your mind you have the process and techniques down quite well. Like I said, I'm confident you'll nail it.
5-9 02:50
Bashy
DowntownRDB Posted at 5-9 02:50
Yeah, it's the same with the roll, there are 5 steps and as long as you complete all 5, you should roll up
Thank you
5-9 03:01
DowntownRDB
Bashy Posted at 5-9 03:01
Thank you
I hope you have a fantastic day Bashy.
5-9 03:29
Gabriel Tallon
Flight distance : 1825823 ft
Nice! Thanks for sharing. That looks like fun!
5-11 17:05
Blériot53
Flight distance : 6269839 ft
Looks like you were having fun. I felt quite exhausted myself by the end
5-12 03:57
A J
Flight distance : 14919065 ft
Looks like a lot of fun Bashy
5-13 00:33
Bashy
Gabriel Tallon Posted at 5-11 17:05
I really is and a tad scary too
5-15 17:58
Bashy
Blériot53 Posted at 5-12 03:57
I was too, exhausted that is lol
5-15 17:59
Bashy
A J Posted at 5-13 00:33
Yeah, it is great fun
5-15 17:59
Gabriel Tallon
Bashy Posted at 5-15 17:58
I'm not surprised
5-15 18:07
Bashy
DowntownRDB Posted at 5-9 03:29
A wee update...
I felt like i had improved even though i swam 3 times again, but then 2 of those were not my fault perse and also we had moved up the course so bigger drops, deffo had improved but i think that that is in part because i took my own yacht and whilts its the same boat it is older, a "Burn 2" and their boats are the "Burn 3", some subtle differences, a thinner cockpit entrance (at the front) on the newer boat and i don't get my big boots stuck behind the front pillar when trying to get out underwater. Not only that, their foot plate (rest) wobbles like hell, thats a put-off for sure especially when a beginner at this discipline.
Whilst those may sound like small excuses, I did feel a big difference when I got on the water in my boat, more confidence, more stable and safer knowing I could get out without trapping my foot for X seconds. Whilst it would be much easier using their boats, what with loading and unloading mine, less drag on the car for the 140-mile round trip, I will deffo be taking mine from now on
The 1st run, that was a copy of last weeks, i did it perfectly (in my eyes lol), certainly didn't mess it up like last week and i had to ask the coach how i can can closer to the eddy line, he didn't offer to tell me where i was going wrong, i had to blooming ask, thats that right, anyhoo, that 1st run was spot on but I forgot to turn on the bl00dy camera, still gutted about that, the rest of the same as last week runs whilst still better, were mediocre, but i know how to setup to start the run and that was my biggest flaw the 1st day.
I have a feeling that i will have to spend another £200 (plus £50 fuel x4) and take the course again because I feel I should be better than I am by now that the 1st day not been a waste. That said, I am nearly at the top of the course, and the coach said that for this Saturday coming, we can either go up or stay as we are and keep practising if we feel we need it, so will have to see, 2 more days left...
5-15 18:31
A J
Bashy Posted at 5-15 17:59
It's not too far from where I live in Enfield so may have to check it out mate
5-15 22:03
Bashy
A J Posted at 5-15 22:03
If you've never kayaked before or have no experience going upside down and having to release the spray deck then I would highly recommend joining a local group 1st and get free (clubs charge a yearly membership fee around £30) advice, guidance etc and there are a few around the area, it will be much cheaper than having to start there at Lee Valley, you can mind but it will be more expensive i would have thought.
If you're already experienced in the above, then yeah 100% go for it
5-15 22:28
A J
Bashy Posted at 5-15 22:28
Thanks for the advice Bashy - local club seems the way forward then.
5-15 22:32
Blériot53
I hope it was fun, though
5-15 22:58
Bashy
A J Posted at 5-15 22:32
For sure, not only that, they normally have an assortment of kit that you can try too, deffo the best way to go
5-16 00:13
Bashy
Blériot53 Posted at 5-15 22:58
Yeah, definitely was.
5-16 00:14
A J
Bashy Posted at 5-16 00:13
Cheers for the tips mate!
5-16 00:19
Blériot53
Bashy Posted at 5-16 00:14
5-16 00:19
DowntownRDB
Bashy Posted at 5-15 18:31
A wee update...
Keep at it and keep your confidence level up.  I'm sure you'll master it.  Too bad the instructor wasn't more forthcoming with information to help you get better faster.  You shouldn't have had to ask, at least that is my opinion.
5-16 03:23
Bashy
DowntownRDB Posted at 5-16 03:23
100% agree with you, no way i should have had to ask, it was plainly obvious that i was struggling with that issue, I could have progressed further than where I'm at at the moment, so i feel a little cheated especially considering that i had to ask what i was doing wrong. In part, i do feel that the boat had some play in holding back my progression too but I will probably never know now as i wont be using that one again.
Thank you, just finding out where i went wrong and using my own albeit older boat boosted my confidence level. I know I have to work on a couple of points and its there that i feel i would have been a little further along, anyhoo, I just hope i can still progress enough to pass the assessment.
5-16 17:53
DowntownRDB
Bashy Posted at 5-16 17:53
With regard to your boat - sometimes older is better.  Just keep your motivation up and you'll succeed.
5-17 03:00
BetterBizTech
Flight distance : 6870043 ft
Looks like a fun day.
5-17 18:15
Bashy
DowntownRDB Posted at 5-17 03:00
Thanks chap
5-18 16:59
12Next >
