Audience vs Pilot Mode
1339 7 2024-5-21
AvroTrain
Flight distance : 1375318 ft
May I hear the definition of the difference between both these modes ?   Audience vs Pilot Mode
Also I thought I heard one can watch the drone feed wirelessly  on an iPhone?
2024-5-21
fichek
Flight distance : 1378789 ft
Croatia
Audience mode allows other nearby goggles to tune into what the broadcasting pilot is seeing.
For live view on your phone via wifi, swipe from the top and enable that feature, then in DJI Fly Goggles will appear under "nearby devices", same place you'd go to for QuickTransfer.
2024-5-21
DJI Tony
Hi there. You can share the live view through either of the following three methods:
1. Wi-Fi Wireless Sharing: Enable “Share FPV to Mobile Device Via Wi-Fi” in DJI Goggles 3, and connect a mobile device to the goggles via Wi-Fi, and then the live view of the aircraft will be displayed on the DJI Fly app in the mobile device. Wireless sharing supports connecting one mobile device only.
Note: Wireless sharing via Wi-Fi is also supported when DJI Goggles 3 works with DJI RC 2 or DJI RC-N2.
2. Wired Sharing: Connect DJI Goggles 3 to a mobile device with the USB-C OTG cable and a suitable data cable, and then the live view of the aircraft will be displayed on the DJI Fly app on the mobile device. Wired sharing supports connecting one mobile device only.
3. Audience Mode: Enable Broadcast Mode in the DJI Goggles 3, and multiple DJI Goggles 3 devices can connect to the broadcast channel, enabling the output of multiple real-time camera views. Audience Mode allows up to three DJI Goggles 3 devices to be connected. Tips: The use of two sharing transmission methods simultaneously is not supported. For instance, if you share the live feed from the goggles to other goggles using the broadcast mode, you will be unable to share it by connecting a mobile device.
Have a nice day.
2024-5-22
A J
Flight distance : 15283773 ft
DJI Tony Posted at 5-22 00:38
Good to know Tony - many thanks
2024-5-22
AvroTrain
YA Thanks will Trynext time I'm out with it.
2024-5-23
DJI Tony
A J Posted at 5-22 06:20
I'm glad to help. You may reach us anytime if you have further concerns. Have a great day ahead.
2024-5-25
DJI Tony
AvroTrain Posted at 5-23 03:59
You are most welcome. Let us know if you have further concerns. Have a great day ahead.
2024-5-25
A J
DJI Tony Posted at 5-25 01:50
Thanks Tony and you too
2024-5-25
