Maximum flight time with one battery Avata-2
6120 14 2024-6-15
vid3
Flight distance : 432835 ft
Poland
Avata-2.
Battery charged to 100%. Landing after reaching 10%.
I made about half a hundred flights.
My maximum flight time is 15-16 minutes.
And what does it look like for you?
2024-6-15
DJI Natalia
Hi there,
‌Maximum Flight Time for DJI Avata 2 ‌Approx. 23 mins, measured when flying forward at a speed of 21.6 kph in a windless environment at sea level, with camera parameters set to 1080p/30fps, video mode off, and from 100% battery level until 0%. Data is for reference only. Always pay attention to reminders on the goggles' screens during your flight.
I hope this information has helped to clarify your inquiries.If you have any other questions, kindly let us know. Thank You!
2024-6-15
vid3
Poland
Hi,
I didn't write about ideal conditions.
Real conditions. We fly to have fun.
The wind blows sometimes weaker, sometimes stronger.
Guaranteed 15 minutes of fun.
Then a quick RTH to replace the battery.
2024-6-16
DAFlys
10-12 typically.   It depends on how fast you fly.
2024-6-16
OldGuy2024
Flight distance : 632428 ft
Using MC3 in S mode. Try landing with 30% of battery capacity remaining. The timer usually reads 4-6 minutes remaining. 12-14 minutes from when starting to stopping motors.  Doubt if I could exceed 16-18 minutes even if dropping capacity to single digits.  Longer flight times when throttle input and flight path is steady (and boring).
Personally would prefer OSD info of actual cell voltage v. the timer.  Or better yet the option to choose between the two. Ability to customize the OSD would be nice. First modern quad owned that does not give that option.  On my non-DJI 3" quad I use voltage sag to determine when to ease back on throttle input and consider landing.
2024-6-16
Dystopia
Finland
Yesterday I went on easy fly and it was about 16mins. Been around there in every flight
2024-6-16
Swedrone
Flight distance : 15419022 ft
Sweden
I land at 20% and have 14-15 minutes of flight in Normal mode not blasting away to much
2024-6-19
djiuser_0ZXG5MK2wpWJ
Does anyone happen to know what the maximum battery time is while not flying and camera film shooting   on?
2024-6-20
DJI Natalia
djiuser_0ZXG5MK2wpWJ Posted at 6-20 06:14
Hi there,
thank you for reaching out.
Before we assist you further, may we confirm if you want to know about the hovering time of the aircraft?
Please keep us posted. Thank you.
2024-6-21
A J
Flight distance : 15283773 ft
My flight times range from literally 8 to 18 minutes
2024-6-22
djiuser_93PGTNtoYEqJ
Flying in Acro mode normally gives you around 10 minutes if you land with 18-20% battery left.
2024-6-24
Nga Kohungahunga Manawanui
New Zealand
5 - 10 mins... though this is due to the battery losing charge when stored. I do a full charge and when I go to use it the battery is almost half spent... wishing I hadn't paid so much for such a poor quality drone.
2024-10-28
yogi053
Flight distance : 26104915 ft
Nga Kohungahunga Manawanui Posted at 10-28 15:54
I suggest you fully charge your batteries before flying and also do not store them fully charged when not flying. Store them between flying days at 40-60 percent.
2024-10-29
Spash
Czechia
I don't see this mentioned much and even asking other owners can lead to surprising "hmm, I have no idea" answers, so adding my "real world" experience that may potentially help some people decide if Avata 2 is a good drone for their needs:
At some occasions I use Avata 2 as a sort of 'urban exploration' drone, which means lot of turning, braking, but mostly slow flying through trees, around bushes, scattered rubble, behind concrete or brick walls, over solid floors and [somewhat reluctantly, but still] shallow cellars... Reluctantly because of Avata's inability to properly hold position in low light conditions, you can lose your drone easily by having it dart from a stop to nearby wall at full speed as it just randomly decided it would be a fun thing to do right now. Generally not a good scenario when in a place with an access impossible in person, or otherwise very hard to get to and save the drone from drowning.
My best run time is 12-13 minutes (with video recording at 2160@60) until the forced landing at <5% battery.
Now, why this is a decent outcome:
1. The drone runs with the FCC hack on, boosting radio power significantly compared to CE (this in turn adds to battery consumption and while I've seen claims of some 3-4 minutes difference, my observation would be about an extra minute at most. Mileage may vary depending on conditions and I didn't test this somehow thoroughly, simply taking FCC as the go-to option, regardless of consumption differences, which are not significant enough to matter). While FCC is not strictly necessary as the radio is still "good enough" in CE for most situations, you probably want to ensure penetration and don't want the drone to randomly decide to return home straight through the roof or a nearest wall because it lost signal for a second.
2. Giving the typical spaces involved, the drone has some extras attached to it - propeller bumpers, aluminium gimbal protection bars, additional mount brackets on top and bottom (can be used for spotlight, extra camera, etc - but these are not calculated in the number above), aluminium motor protection shells, landing support legs (Avata's propellers are very close to the ground, which can be incompatible with scattered rubble - some extra ground clearance always helps.) Even if each extra piece attached to the drone is "just a few grams", in the end this adds to about 15% total weight increase and likely throws out balance in some way, increases drag, maybe adds vibrations that need to be compensated by the motors running at extra power and so on.
3. As also stated in posts earlier, if you did not charge your batteries freshly before the flight, the capacity can be unpredictably lower sometimes - I've observed a battery claiming to be full then go down from 100% to 82% in a matter of seconds until it "settled" on the new percentage and continued properly afterwards.
Now, the worst case scenario when crossing larger distances, up hills, in strong winds - is still about 8 minutes of fully controlled flight. Some extra minutes need to be reserved for return time while the battery charge can be dropping very fast (as you're pushing quickly back home, not realizing this is making the situation even worse). If you miscalculate one or the other way and run it to empty battery somewhere over a dense forest, you're not ever going to find the drone again. So assuming "close to 10 minutes, but something below that, 8-9 to be safe" in windy hills is about a right idea to have. Then of course, for flying over hills you may want to strip away any rugged parts to lose that extra weight, but this is not always very practical with screws (which usually change the original DJI screws for different lengths fitting the extra mods and you probably don't carry several sets to swap them on the go for every situation).
So anyway, of course the advertised "maximum flight time" of 23 minutes is nonsense, even a freshly unpacked vanilla Avata 2 (clean, pristine propellers, no damage, no mods, freshly topped battery, etc.) doesn't come anywhere near that. But if you can settle for half of the advertised 'paper time' in exchange for a decently rugged drone setup with very good signal penetration, then Avata 2 can fit that bill. I also use a DJI Neo with similar setup (added bumpers, gimbal protectors) and in the same scenarios can generally last about 50% longer before running empty, making it to around 18 minutes. But of course with the much worse overall performance and the bad camera that comes with Neo (and other downsides like no SD card, etc.)
(And just in case, before someone comes with "hurr durr radio spectrum laws, VLOS regulations, spotter, etc." - all my mentioned tests were conducted on a deserted island in the middle of the Pacific ocean on a private indoor property inside a closed hangar. There you go.)
2024-10-29
OldGuy2024
Using the FPV RC3 in S mode. Both Avata2 and Neo are delivering ~10 minutes of flight times down to ~30% battery capacity level.
Flying the Neo in Manual mode, but gently the flight times drop to ~7 minutes.  Guessing will be similar with the Avata2.
2024-10-30
