kenargo
There is a company, out of the UK I believe that sells a camera mount that can be used with nearly any camera. If you had that mount I suspect you could choose nearly any compatible camera and gimbal you wanted and as the mount supports detachable mounts it would make it easier to remove when you wanted.
I need to search a bit to find them...
