RTH not working
836 7 2024-6-18
EvidencePress
Flight distance : 270728 ft
  • I purchased the AVATA 2 a few days ago. I have flown it a few times. But the RTH does not work. It just sends the drone down to land, it does not return home. I tried going back in the DJI Assistant to go back to an older firmware but I don't have an option for that. Seems like a software issue. Any thoughts on what I can do?
2024-6-18
SaurabhSrivastava
Flight distance : 2380479 ft
India
Hope you are atleast 100m away when you trigger the RTH. Also, ensure that you have RTH selected under safety -> advanced menu. Before you fly, ensure you have a Home point recorded notification.
2024-6-18
DJI Natalia
Hi there, thank you for reaching and we do apologize for any inconvenience caused. Kindly take note that the aircraft cannot return to Home if the GNSS signal is weak or unavailable and the aircraft will automatically descend or land. Also, make sure to set the RTH altitude before each flight.
You may get more information on the RTH Procedure in the User manual from pages 44 to 46. I've also shared the link below for your reference.
( https://dl.djicdn.com/downloads/ ... _Manual_v1.0_en.pdf )
Thank you for your understanding and support.
2024-6-18
djiuser_ofR8Bb3sjjh9
Flight distance : 86601 ft
SaurabhSrivastava Posted at 6-18 14:06
I had my Avata 2 ascending to high attitude instead of descending after I hit the return to home yesterday several times.  It was about 40metre high, after I hit RTH, It flew up to 250 metres several times. Firmware all updated. Can someone pls help?
2024-6-21
SaurabhSrivastava
India
djiuser_ofR8Bb3sjjh9 Posted at 6-21 15:23
A video with Goggles view would be helpful
2024-6-21
DJI Natalia
Hi there,
thank you for reaching out.
Before we assist you further, can we ask you to share the video? This may help us analyze the situation better and resolve the issue.
Looking forward to your response. Thank you.
2024-6-22
A J
Flight distance : 15283773 ft
Make sure the RTH altitude is set accordingly in the app
2024-6-23
Sean-bumble-bee
Flight distance : 15997 ft
Post the flight log.
In what part of the RTH process were you expecting the drone to descend ?
Was obstacle avoidance enabled during the RTH, if so did it detect obstacles ?
As pointed out by AJ, what was the RTH height set to ?
2024-6-23
