Mavic 2 unable to take off Error 180
1036 9 6-18 19:36
WaterMaster
Using a DJI Remote Controller when I try to take off I get a message: Unknown Error (code 180) cannot take off contact support
I found I had updated the firmware but not the APP
6-18 19:36
DJI Natalia
Hi there, thank you for reaching out and we do apologize for any inconvenience caused. May I confirm if you're using DJI RC for your Mavic 2 Zoom? Please note that DJI Mavic 2 Zoom is only compatible with DJI Smart Remote Controller.
Thank you for your understanding and support!
6-18 20:37
djiuser_lXgE4QdMqXtz
DJI Natalia Posted at 6-18 20:37
I am having the same issue.  I have the Mavic 2 Zoom and using the Smart Controller.   Please advise how to fix. Thanks.
6-22 11:37
DJI Natalia
djiuser_lXgE4QdMqXtz Posted at 6-22 11:37
Hello there, thank you for reaching out. We are sorry for the inconvenience caused. Pertaining to your issue, please try the troubleshooting steps below :
1. Check whether the firmware and app are updated to the latest versions (most updated app version: 4.3.60). Please check the app version on the “About” page in DJI GO 4.
2. Check whether the GPS-related options are enabled in the app and whether the app is running in the background.
3. If this issue persists after going through the steps above, please provide us with the following information via PM :
  • A screenshot of the malfunction
  • Firmware information
  • Flight control logs
  • App logs
Looking forward to your updates. Thank you.
6-22 12:45
Capt. Wild Bill Kelso
Flight distance : 1319180 ft
Same issue here.
You must upgrade controlller.
10-18 13:44
DJI Diana
Flight distance : 2408 ft
Capt. Wild Bill Kelso Posted at 10-18 13:44
Same issue here.
Hi there,
We recommend you check whether the firmware and app are updated to the latest versions. You can check it via "About" page in DJI GO 4. Then, check whether the GPS related options are enabled in the App, and whether the App is running in background.
Looking forward to your response.
10-18 23:24
DJI Diana Posted at 10-18 23:24
Hi there,
Um…
After I said “same issue here”.
I advised the original poster how to rectify error code 180.
I did what I suggested and solved problem.
10-19 15:39
DJI Natalia
Capt. Wild Bill Kelso Posted at 10-19 15:39
Um…
Hi there, thank you for the update and we're glad to hear that you're able to solve the issue by following the suggestions shared. Do not hesitate to contact us if there's any further inquiry.
Thank you for you valued support!
10-20 03:30
djiuser_wNRiXAH5oeqL
My Go 4 version is 4.3.54.  I cannot find a way to update.  There is nothing in DJI Assistant 2, or any place else that I can find.
12-15 09:48
DJI Diana
https://www.dji.com/downloads/djiapp/dji-go-4
djiuser_wNRiXAH5oeqL Posted at 12-15 09:48
Hi there,
Have you tried reinstalling the application to see if it resolves the issue? Please download the App from our download channels.
Feel free to contact us should you have any other questions.
12-17 01:10
