DJI Fly app latest version 1.13.8 problem
4164 27 6-28 02:57
kon_boz
Flight distance : 62589 ft
Greece
Hello, yesterday I updated to the latest fly app version (1.13.8 from 1.13.5) and I found out today that there is a problem with the waypoints planning. If I plan a waypoint mission from the map and save it, then if I go back and try to load it the app crashes. This happens for missions planned after the update, previously planned missions load just fine. Has anyone else encountered this?
6-28 02:57
DJI Natalia
Hi there,
thank you for reaching out.
We apologize for the unpleasant experience. Are you encountering any error messages on the app or is it simply closing? Have you attempted to restart?
Looking forward to your response. Thank you.
6-28 03:21
kon_boz
Greece
DJI Natalia Posted at 6-28 03:21
Hi there,
No, the screen turns black and then I go back to the start screen. If this happens a couple of times I get a warning from Android that this app keeps not responding. It doesn'e crash completely or maybe it does and then restarts. I have restarted the phone but nothing changed
6-28 03:33
DJI Natalia
kon_boz Posted at 6-28 03:33
Hi there, thank you for sharing the details above and we're do apologize for the trouble. It would greatly help if you could share us an operation video demonstrationg the issue for us to have better understanding on the condition. It'll also help us to investigate further with our engineering team
Looking forward to your response. Thank you for your understanding and support!
6-28 03:46
kon_boz
Greece
DJI Natalia Posted at 6-28 03:46
I have uploaded here a demonstration of the problem:https://youtu.be/xdSNqNRfjdk
As you'll be able to see, a mission planned today (after the update) cannot be loaded but a mission planned before the update is loaded fine
6-28 05:43
Va1entin2
Flight distance : 393816 ft
Romania
It seems that DJI has stopped the update process for drone firmware, controller and the Fly application. Is there any reason for this?
6-28 05:47
MiniManiac
Flight distance : 1311368 ft
Va1entin2 Posted at 6-28 05:47
Seems to be a typical DJI thing, release a FW realise it doesnt work.
When will this super large very rich company actually test updates instead of making us poor saps risk our quads with faulty updates
6-28 09:18
kon_boz
Greece
There should be an easy way to rollback to a previous version. I didn't find a way other than unistalling the app and losing my settings or fiddling with folders in order to keep the settings intact
6-28 09:30
DJI Natalia
kon_boz Posted at 6-28 05:43
Hi there,
Thank you for providing us the video.
Please be informed, there is a new firmware update for Mini 4 Pro.
Kindly proceed to update the aircraft and retry again.
If the issue still persist, kindly revert back to us.
Thank you for understanding.
6-28 09:34
kon_boz
Greece
I have updated the drone firmware after the app update. It shouldn't be a firmware problem as this happens even when I am not connected to the drone or the rc remote. I am just planning routes from my phone through the map
6-28 09:37
DJI Natalia
kon_boz Posted at 6-28 09:37
Hi,
Kindly try create a new waypoint flight mission to test if it crashes. And do revert back to us if the issue still persist.
Thank you for your patience with us and understanding.
6-28 11:43
djiuser_oqgEF3jeeMPr
Flight distance : 213770 ft
I’ve been experiencing the same issue since I updated the mini 4 pro and the controller; at this moment, it’s not possible to create new waypoints because Dji fly keeps closing continuously…
6-28 11:45
fans40fed5ef
Flight distance : 1693 ft
I have the same issue rc2 with Air 3 - latest firmwares…
6-28 12:17
fans40fed5ef
I am having the same exact issue - when I go to load in a newly saved waypoint the app crashes….
6-28 12:49
DJI Natalia
djiuser_oqgEF3jeeMPr Posted at 6-28 11:45
Hi there,
Kindly send us the App's Log File for us to investigate and assist you further.
Thank you.
6-28 15:53
DJI Natalia
fans40fed5ef Posted at 6-28 12:49
Hi there,
Thank you.
6-28 15:53
DJI Natalia
fans40fed5ef Posted at 6-28 12:17
Hi,
6-28 15:54
Manitobahunter
Not sure about the phone fly app, but if you check your cache in the RC2 after the update, you'll see its showing red, and you are out of space and need to clear the cache. I literally take all my files off my SD card and controller, and clear my cache and flight logs after every flying session. Keeps things organized and never have to worry about a lack of storage.
6-28 17:42
kon_boz
Greece
Thought about cache when it started doing it and cleared it, didn't change anything. Also isn't related with mission complexity; even a mission with one waypoint will crash if you try to load it. It's a pretty straightforward bug, it will probably get fixed some time, hope soon.
6-28 19:55
kon_boz
Greece
Update is already out and fixes the issue, good job!
6-28 21:41
DJI Natalia
kon_boz Posted at 6-28 21:41
Hi there,
We appreciate the update given to us and for other DJI Forum users.
Should you have any other questions, kindly message us for assistance. Thanks!
6-28 23:06
Va1entin2
Romania
A few moments ago I made an update to version v1.13.9 (not v1.13.8). I have no problem with waypoint mission, I can create and load them without problems. Good gob DJI.
6-28 23:27
fans40fed5ef
Issue fixed in DJI Fly 1.13.9
6-29 04:44
DJI Natalia
Va1entin2 Posted at 6-28 23:27
Hi there,
Glad that it worked out for you. We appreciate the update given to us and other DJI Forum users.
Should you have any other questions, feel free to contact to for assistance. Thanks!
6-29 20:57
AndyGutsell
Flight distance : 1862756 ft
I also have an issue with the app. I have found that in the last few weeks, when I go into my profile to check my flight records, I can no longer see the preview photos associated with each flight !
Is this a known problem ?
Is there a fix for this?
7-12 07:13
AndyGutsell
AndyGutsell Posted at 7-12 07:13
7-12 07:16
AndyGutsell
Why no response ?!?
7-13 16:35
FC Bayern
Flight distance : 110745 ft
North Macedonia
https://www.suasnews.com/2024/06 ... ly/#google_vignette
Maybe you should google a bit before panicking!
7-14 10:13
