Firmware Update 1.13.9, 01.00.0600, 02.02.0200
1759 35 6-29 05:53
Manitobahunter
Another firmware update for the RC2, version 02.02.0200, and a new fly app version 1.13.9. Did the update over the air on my home wifi network, and went smoothly. I see mention on you tube the update was done to solve an issue with hyperlapse principles in the previous version. Make sure you clear your cache after each update, Firmware Update 1.13.8, 01.00.0600, 02.02.0100 was quite large.
6-29 05:53
In the sun
Flight distance : 1685072 ft
The firmware updates seem to be a moving target. Thursday there was one, friday I had missed it and would not update. Today it did with newer version.
6-29 06:06
Manitobahunter
Yep its morning coffee, check the news, update DJI firmware and head to work As long as things are moving in a positive direction, I'm good with firmware updates. I went out for a short test flight, flew a ways away, and back, did the same again and let the drone auto return to home. Still boots up fast and regular flying seems to work, but didn't have time to test out the automated camera features.
6-29 06:27
MiniManiac
Flight distance : 1311368 ft
Well I did update and all seemed fine, just got back to find a hyperlapse and a Pano shot I took isnt anywhere to be found, it did complete as it shows on the screen recording i always do when flying, plus all the files for both HL and pano are on the SD card
I have a file on the SD card J:\DCIM\DJI_001\.djivideo4180968075453888101.mp4, which is corrupted
6-29 11:00
HeavensAboveD
Flight distance : 77976 ft
MiniManiac Posted at 6-29 11:00
Have you tried changing the folder name to something else?
Go to Fly Now -> ... -> Camera -> Storage -> Custom Folder Naming -> Enter Letters & Numbers or just Numbers or Letters whatever you want it to be (only Numbers and Letters are available) and then try recording again to see what happens.
6-29 16:04
DJI Natalia
Hi there,
Kindly try with a new microSD card and let us know if the issue still persist. Check the official website for microSD compatibility with your DJI product before purchasing.
We are looking forward to your response for further assistance. Thank You
6-29 23:14
DJI Natalia
Hi there,
Thank you for sharing your resolution. This sure will help other users whose having the same issue. Have a safe flight always!
6-29 23:27
DJI Natalia
In the sun Posted at 6-29 06:06
Hi there,
We apologize for the inconvenience. The firmware update is for providing better experience for our customer by fixing some known issues. Are you able to update your firmware? If the App method fails please try updating via DA 2.
6-29 23:34
weedhopper
Flight distance : 85686 ft
Hello
Not really serious !!!
6-29 23:45
Manitobahunter
The DJI assist 2 sometimes takes days for an update to show as available once an over the air update has been released. Same as the DJI website, it still shows 1.13.8
Do the update over a fast wifi network, and be brave and think happy thoughts while its updating If you can, put a small fan pointing at the front of your drone during the process to keep the little guy chill.
Tip for using the DJI assist 2 is only have the DJI device you are updating via a DJI usb cable plugged into your PC powered on while updating it. If you're having issues with the DJI assist 2, uninstall and reinstall it, and make sure you have the correct version of the assist installed, in this case, the consumer version for the MIni 4 Pro.
The correct sequence of events is: power up the DJI device to be updated, open the DJI Assist 2 program, and once its showing you the little USB A getting plugged in animation, plug the device to be updated into the PC. The Assist 2 will detect the device and display it, click on the device icon and it will show you your options to refresh the current firmware or update to a new firmware if available. Pick your option and don't unplug anything until it shows 100% and complete. Sometimes it will revert back to the device icon when its done and sometimes it will just sit there showing you 100% and you can click the back arrow to do back to the device icon, and then you can unplug the device being updated.
6-30 07:41
_SoP_
Flight distance : 997556 ft
I updated today (OTA) and went for a short flight. It seems all is OK.
7-1 10:38
Burt37
Flight distance : 4009 ft
weedhopper Posted at 6-29 23:45
Hello
DJI doesn't release updates for every region simultaneously, otherwise their server network would collapse...
Not sure where France is in the queue, but you will eventually get the updated available based on server demand...
7-1 18:06
DJI Natalia
Manitobahunter Posted at 6-30 07:41
Hi there, thank you for sharing your ideas and valuable information. We sincerely appreciate the time you've taken to share these ideas with us and our fellow users.
Keep us posted always! Thank you for your value support!
7-1 23:54
DJI Natalia
_SoP_ Posted at 7-1 10:38
Hi there, thank you for sharing the update. We're delighted to receive your positive feedback, and we sincerely appreciate the time you've taken to share it with us. Your feedback is valuable to us, and it motivates us to continue providing the best possible experience.
Keep us posted always! Thank you for your valued support!
7-1 23:57
Struthio
Poland
Two questions:
1. What is latest firmware for Mini 4 Pro ?
This post mention " 02.02.0200, and a new fly app version 1.13.9" but Firmware page (Page "New DJI Mini 4 Pro Firmware Released") says that update on "2024.06.27" brought us " v02.02.0100 and DJI Fly at v1.13.8" ?
2. Are there any 'side effects' of this firmware, not mentioned in changelog ? (like this previous battery ban ?)
7-2 02:35
DJI Natalia
Struthio Posted at 7-2 02:35
Two questions:
Hi there, thank you for reaching out. The latest firmware version for DJI Mini 4 Pro will be as below :
Aircraft Firmware: v01.00.0600
Remote controller Firmware: v02.02.02 ( DJI RC 2 )
                                                             v01.01.03 ( DJI RC-N2 )
DJI Fly App IOS : v1.13.9
DJI Fly App Android: v1.13.9
This latest firmware updates has fixed the known bugs and there's no side effects from this new update. DJI recommends tp get the latest update as outdated firmware can sometimes cause glitches.
Thank you for your understanding.
7-3 00:19
IHI
Cambodia
DJI Natalia Posted at 7-3 00:19
Based on the official information new firmware  Added support for Enhanced Transmission in some countries and regions. Can you please share list of supported countries and regions ?
7-3 23:37
DJI Natalia
IHI Posted at 7-3 23:37
Hi there,
Thanks for the inquiry. We are unable to provide details on the regions as the details are handle by the relevant department. Please rest assured that we will forward your feedback to the related department for evaluation. In the future, we will optimize and improve the product or service based on user comments.
I hope this information has helped to clarify your inquiries. If you have any other questions, kindly let us know. Thank You!
Thank you for your support and understanding.
7-3 23:47
The Ollie
Flight distance : 116362 ft
This is exactly what I mentioned in my post : Release Notes
(Details would be nice)
7-4 03:22
DJI Natalia
The Ollie Posted at 7-4 03:22
Hi there, thank you for sharing your concerns. Your feedback is valuable to us, and we will ensure that it reaches the appropriate team for careful consideration and evaluation. Our commitment to delivering the best user experience remains unwavering, and we sincerely appreciate your continued support.
We are grateful for your ongoing support. Thank you!
7-4 23:09
DJI Natalia
Hi there,
Thank you for your recommendations. Please rest assured that we will forward your feedback to the related department for evaluation. In the future, we will optimize and improve the product or service based on user comments.
7-4 23:16
ErrkaPetti
Sweden
DJI Natalia Posted at 7-4 23:16
Hi there,
Really hate this automated AI bot-answers from Dji!
7-4 23:44
Manitobahunter
If you go on You Tube and search the updates, you'll see a ton of information in various video's from content creators about whats been changed and what was fixed, and yes it would be nice if DJI spilled the liability beans, lol...but thats unlikely.
7-5 21:03
DawidO_0
Flight distance : 89265 ft
Poland
Unfortunatly  after update Mini 4 Pro is over responding and cannot hover stable in air, also during fly struggle a lot even with a weak wind, also app is crushing, cannot use manual tracking, when using tracking circle drone is always reseting/losing connection, also video feed is stuttering, please do not install it.
7-15 01:45
Serg SSA
Flight distance : 6627913 ft
Russia
DawidO_0 Posted at 7-15 01:45
Why are you sure that everyone has your problems? What kind of remote control do you have? N-2 probably... So maybe the problem is in the phone you are using?
7-15 01:54
DawidO_0
Poland
Serg SSA Posted at 7-15 01:54
Nope, I have RC2, also drone is fresh, have it one month, was working all ok till last weekend update.
7-15 08:06
Serg SSA
Russia
DawidO_0 Posted at 7-15 08:06
I updated immediately when the new firmware appeared. Everything is fine with me, yesterday I flew for about an hour and did not notice any problems.
7-15 08:32
DawidO_0
Poland
Serg SSA Posted at 7-15 08:32
Try to hover in front of you, check if it is steady, small wind needed like 5-8 m/s, also check manula tracking and use manual ring and try to rotate around object in move, reg. hover in my drone rear end is jumping.
7-15 11:59
Manitobahunter
Calibrate your compass and IMU.
7-15 22:09
Serg SSA
Russia
DawidO_0 Posted at 7-15 11:59
I usually shoot video, I haven’t noticed any problems, I fly to different distances and the flight paths are complex with many turns and movements. Can you do a factory reset on the remote?
7-16 00:20
DJI Natalia
Hi there,
We are truly sorry for the inconvenience you are experiencing. However, the Firmware update should not cause such issues. Could you check if you have updated the DJI RC2 to the latest firmware version too (v02.02.0200) and the DJI Fly App v1.13.9. As the last step if the issue still exists please proceed with IMU calibration.
Upon all the above steps if issue still persist, please send us a video recording of the problem. This will allow us to investigate further and provide you with the most accurate solution based on the specific issue you're encountering.
7-16 00:59
DawidO_0
Poland
Serg SSA Posted at 7-16 00:20
I will try, last resort, thanks for sugestion.
7-16 06:10
DawidO_0
Poland
DJI Natalia Posted at 7-16 00:59
Hi there,
Thanks for info, I did calibration, still over reacting, but Your service told me after video review that it is still in tolerance beside that it was dealing better with much stronger wind before software update, I can only hope that gyro will act better / like before update after next software update.
7-16 06:14
DJI Natalia
DawidO_0 Posted at 7-16 06:14
Thank you for the response. May we confirm which service you are referring to? You may provide us the video footage as well to check further on this matter.
7-16 15:37
DawidO_0
Poland
DJI Natalia Posted at 7-16 15:37
DJI online service, case was also discused on chat support.
7-17 02:50
DJI Natalia
DawidO_0 Posted at 7-17 02:50
Hi there,
Please send us a video recording of the problem. This will allow us to investigate further and provide you with the most accurate solution based on the specific issue you're encountering.
7-17 03:31
