FPV Remote 3 having issues
902 2 2024-7-1
Brian Saner
Flight distance : 2160079 ft
Im having a problem with my fpv remote 3 for my avata 2. My issue is that when in manual mode my fpv remote 3 is having a delay in the yaw stick. It gets very scary to fly because i dont know when it will delay and wont allow me to turn fast or even turn at all. I almost crashed multiple times because when i move the yaw stick left or right i can see a delay in the movements, either it will go very slow and then suddently feel like its stuck and keeps turming or it wont let me turn at all. At first i thought it was my avata 2 doing it becasue i only noticed it after a small crash into bushes, all the props are good and no damage at all. The only other thing i did after the crash was reupdate everything and recabiltate everything (fpv remote 3, avata 2, and goggles 3). I know its my remote 3 because i used it in the liftoff sim and it did the same delay in the yaw stick. Very weird though is that if i use it in normal or sport mode then it works perfect, its only when i flip it to manual mode is when i notice the issue (even in liftoff only when toggle to manual mode). My question is, Does DJI repair fpv remotes? If so how would i go about doing that.
2024-7-1
DJI Natalia
Hi there, thank you for reaching out and we do apologize for the trouble caused. May I confirm if you've tried calibrating the control sticks? If not kindly follow the steps below to calibrate the control sticks in your remote control. If the calibration is already done, then kindly recalibrate it and check  if it works :
-On the calibration screen, you'll see instructions and visuals for calibrating the control sticks.
-Follow the on-screen prompts to move the control sticks throughout their full range of motion. This typically involves moving them all the way up/down, left/right, and diagonally.
-The app will guide you through the process, and once complete, you'll see a confirmation message.
If the issue persists after the calibration, please be advised to send back your remote controller for full diagnosis.  The corresponding team will advise you accordingly after the inspection. You may submit the repair request at :
[ https://repair.dji.com/hk/repair/index ]
Thank you for your understanding and continued support!
2024-7-2
RYZU
Flight distance : 1148776 ft
I am having the same issue - only in manual mode. Controller has been calibrated a few times with no improvement. in simulator and in beta flight all seems fine - in sport and normal mode on avata 2 and neo all is fine - it only hitches / stutters in manual mode. it also happens in the O3 air unit. it is very unsafe.
1-7 01:08
