MAVIC 3 & GOGGLE 3 CONNECTION PROBLEM
903 2 2024-7-6
erl
Flight distance : 1434806 ft
Turkey
Hello, i bought avata 2 full set and i also have mavic 3 pro. I am trying to connect goggle 3 with M3pro. All devices is up to date via assistant 2 from computer. The problem is, in switch list at goggle only AVATA 2 - AIR 3 - MINI 4 pro is listed. The other drones including M3pro is not listes. At tutorials and youtube videos there should be a long list even including O3.
What sould i do ?
2024-7-6
DJI Natalia
Hi there,
thank you for reaching out.
Currently, the Goggles 3 only supports DJI Air 3, DJI Mini 4 Pro, DJI RC 2, and DJI RC-N2 aside from the Avata 2 but we will forward this to the relevant team as a suggestion. Kindly refer to this link for accessory compatibility for the drones: (https://support.dji.com/help/con ... p;re=US&lang=en).
Should you have any other questions, kindly message us for assistance. Thank you.
2024-7-8
djiuser_4HRmjiB5q2Iz
i have the same problem, its advertised that the Mavic 3 pro is compatible with the goggles 3 but when you go to switch there is no option to select the mavic 3 pro
2024-9-10
