a2 led yellow green
1213 5 2015-9-17
alexclima
Brazil
Hello, I have a S900 with a2. When I turn on the s900 it initializes as GPS but after a few seconds the green and yellow LED light up and then stop, one minute after they light up and stop. I dance to calibrate the compass, light a green light saying it was carried out successfully and the problem returns. Please help.
2015-9-17
DJI-BladeStrike
Flight distance : 872694 ft
What does the assistant say, does it still say compass calibration required?
2015-9-19
alexclima
Brazil
DJI-BladeStrike Posted at 2015-9-20 00:17
Yes.  But the problem is the assisstant say is everething is ok, then start the problem with the compass. I repeat the dance, the assistant say you are ok to go and the problem continue.
2015-9-23
DJI-BladeStrike
Have you tried different locations? If so it seems like you have a bad compass and need to contact support.
2015-9-23
alexclima
Brazil
DJI-BladeStrike Posted at 2015-9-23 22:29
Have you tried different locations? If so it seems like you have a bad compass and need to contact s ...
then what part should I change?
2015-9-25
DJI-BladeStrike
alexclima@gmail Posted at 2015-9-25 21:04
The compass is in the GPS puck. I would contact DJI support and request an RMA.
2015-9-25
