D-Log M file size
613 2 7-7 10:18
FoX13000
Belgium
I shoot everything is HEVC and not (yet) in the "PRO" mode.
My question: If I would shoot in the "PRO" mode, and enable the "D-Log M", would the file size be larger than I have now, if i shoot exactly the same footage?
7-7 10:18
Hemon_DOP
Flight distance : 255387 ft
Russia
You can enable these settings and you will see how the remaining recording time on your SD card will decrease.
7-7 23:07
DJI Natalia
Hi there, thank you for reaching out. Yes, shooting in "PRO" mode with "D-Log M" enabled on your DJI Osmo Pocket 3 will likely result in larger video files compared to using the standard video mode. Here's why:
1) D-Log M: D-Log M captures a wider dynamic range with more color information compared to the standard video profile. This additional data requires more storage space, leading to larger file sizes.
2)PRO Mode: PRO mode typically offers higher bitrates compared to standard video mode. Bitrate refers to the amount of data used to store video information per second. A higher bitrate translates to better quality and more detail but also increases file size.
You can also refer our User manual page 318 for more details regarding this at
[https://dl.djicdn.com/downloads/ ... _Manual_v1.0_en.pdf ]
Thank you for your understanding and support!
7-8 03:19
