Transfer files to Windows.
3680 28 2024-7-9
franksstudio
Flight distance : 12448 ft
I have a little problem, when I format the sd card in the DJI Osmo Action 4, I can not transfer files via the OTG/USB connection to a Windows 11 computer, only to the MiMO App, Apple and Linux computer. When I format the card on a Windows computer and put it in the camera there are no problems. Anyone have this too ?
2024-7-9
Fishycomics
I transfer to the pc, via usb C/OTG, I either delete all off the driver, then the next time I am ready I format, shoot, and transfer, to repeat.   No issues, win 11  user
2024-7-9
franksstudio
Fishycomics Posted at 7-9 10:11
Ok thats a work around but when you take a second video after the first video it will not work.
2024-7-9
Fishycomics
I take like 50 plus files. and got no issues for me.
2024-7-9
johansenfoto
Flight distance : 1180089 ft
Norway
Easiest I found out is to just use a card reader
2024-7-9
DJI Diana
Flight distance : 2408 ft
Hi there,
thank you for reaching out.
If you need to export to your computer, kindly follow these steps below.
Method 1: Device and computer connection export
1. Turn on the device, use the data cable to connect to the computer through the USB-C port (charging port) on the side of the camera.
2. A prompt will appear on the camera interface of the device, please select "File Transfer/OTG".
3. Open the SD card disk on your computer, find the "DCIM" folder, and copy out the required videos/photos.
Method 2: Export via card reader
- Remove the SD card from the camera and insert it into the card reader, then connect the card reader to your computer to export.
For a detailed step-by-step guide, you can also refer to this article: https://support.dji.com/help/con ... ;paperDocType=paper
Should you have any other questions, kindly message us for assistance. Thank you.
2024-7-10
franksstudio
DJI Diana Posted at 7-10 21:36
Hi there,
This is only working with Apple iOS and Linux computers, but not with Windows 10/11 computers, the Osmo Action format the card in a way Windows can't handle. I have contact DJI technical support for this problem and the are looking at this.
2024-7-10
DJI Natalia
franksstudio Posted at 7-10 22:19
Hi there, thank you for the update and we're sorry to hear that the above steps didn't work. May I confirm if the issue still persists? if yes, could you please share us a video demonstration showing the issue for us to check further on this?
Looking forward to your response. Thank you for your patience and support!
2024-7-10
franksstudio
DJI Natalia Posted at 7-10 23:00
I have made a video of it you can see it in this link.
I did the folowing : Format the sd card in the camera.
                                  Made a video
                                  Plug in the usb in the computer OTG/USB
                                  Format error in Windows 11
                                  Video still visable on the camera.
                                  Latest firmwware is on the camera 01.04.07.10
2024-7-11
DJI Natalia
franksstudio Posted at 7-11 02:37
                                  Made a video
Hi there,
It seems the MicroSD card that you are using with DJI Osmo Action 4 is SanDisk Extreme PRO 128 GB is not listed under our recommended MicroSD Cards under specs information. You can check the info here DJI Osmo Action 4 Specs This error could be the caused by a microSD card compatibility issue.
Could you try again with the recommended MicroSD Cards from the list below;
Recommended models:
SanDisk Extreme PRO 32GB U3 A1 V30 microSDHC
Kingston CANVAS Go! Plus 64GB U3 A2 V30 microSDXC
Kingston CANVAS Go! Plus 128GB U3 A2 V30 microSDXC
Kingston CANVAS React Plus 64GB U3 A1 V90 microSDXC
Kingston CANVAS React Plus 128GB U3 A1 V90 microSDXC
Kingston CANVAS React Plus 256GB U3 A1 V90 microSDXC
Lexar Professional 1066x 64GB U3 A2 V30 microSDXC
Lexar Professional 1066x 128GB U3 A2 V30 microSDXC
Lexar Professional 1066x 256GB U3 A2 V30 microSDXC
Lexar Professional 1066x 512GB U3 A2 V30 microSDXC
Kindly try the recommended SD Card and let us know if issue still perssist. We are looking forward to your response for further assistance. Thank You
2024-7-11
franksstudio
DJI Natalia Posted at 7-11 20:15
Hi there,
Thank you for looking at my video, yes I see it now, I will try an other card from the list, that can be the problem.
2024-7-11
DJI Natalia
franksstudio Posted at 7-11 22:10
Hi there,
You're welcome! Please try using the recommended list and let us know how it goes. We are looking forward to your response for further assistance. Thank You
2024-7-11
franksstudio
DJI Natalia Posted at 7-11 23:24
Hi there,
I get in the shop the recommended card Kingston CANVAS Go! Plus 128GB U3 A2 V30 microSDXC,
I have the same symptoms with my Windows computer.
When I connect via OTG/USB the first time it works after safe disconnect the camera from the computer, and make a video, and plug it back in the computer I get the message "this card must be formatted "
So nothing have change,  I discover when I format the sd card in Windows with a cardreader ( so not in the camera ) it is working, so I think its the way the Osmo Action 4 is formatting the card is not right for Windows computers.
2024-7-12
DJI Natalia
franksstudio Posted at 7-12 11:15
I have the same simptoms with my Windows computer.
Thank you for getting back and letting us know that the issue has been resolved. We appreciate your feedback and are glad that we could assist you effectively. If you encounter any further issues or have any questions in the future, please don't hesitate to ask.
2024-7-12
franksstudio
DJI Natalia Posted at 7-12 13:54
No it's not solved as you can reed in my message, with the new recommended card I have the same symptoms, the format error in Windows, I hope Dji will solve this with a new firmware update on the osmo action 4 camera for Windows users in the future.
2024-7-12
DJI Natalia
franksstudio Posted at 7-12 23:48
Hi there, we apologize for the inconvenience and appreciate your feedback. To avoid any misunderstanding, we have made corrections to the previous reply. We understand issue has not been resolved and we are more than happy to assist further. As I can see 10# your latest firmware is 01.04.00.10. Our latest firmware version is running on v01.04.07.10 you can keep track here DJI Osmo Action 4 Firmware Released
Could you try to update to the latest version, restart your device and try again. We are looking forward to your response for further assistance. Thank You
2024-7-13
franksstudio
DJI Natalia Posted at 7-13 01:36
Sorry I was typing it wrong , I am running the latest firmware already 01.04.07.10.
I did some research and I discover that the camera format the sd card in an Linux based file system,
so the boot sector of the card is not recognized by Windows and gives that format warning.
2024-7-13
johansenfoto
Norway
franksstudio Posted at 7-13 01:46
That's not correct, then it should not be possible to read the card with a card-reader that I use on my Win10 pc.
2024-7-13
franksstudio
johansenfoto Posted at 7-13 06:16
Do you format the card in Windows, when I format the card in the camera I have the same problem in a card-reader, the bootsector on the card is corrupt.
2024-7-13
johansenfoto
Norway
franksstudio Posted at 7-13 09:35
I never format in windows and always in camera.
Then it's something faulty with either your card-reader, or card or camera.
2024-7-13
franksstudio
johansenfoto Posted at 7-13 12:56
Thank you Johansen, it got me thinking, what I did was connect the camera via the OTG/USB cable to transfer the images, after disconnect the camera from the Windows computer the card becomes corrupt. I now only use a new purchased cardreader and thats going very well no problems. It's just a bit more difficult because you have to remove the card from the camera and put it in the cardreader , but it's manageable this way :-)
2024-7-13
Iancraig10
I also use win 11 and get no issues. I format every time I make a new video in camera and my computer sees the files. It looks like there may be an issue with the Action. Windows doesn’t have some form of protection to stop usb’s working without permissions or something do they?
2024-7-13
franksstudio
Iancraig10 Posted at 7-13 23:08
Hi Ian, when I format in the camera and make a video the first time I plugin the camera with the usb cable I see the files, but after disconnect the camera from the computer and plug it in again the card is not readable in Windows and you have to format it again. I think indeed its a sort of protection from Windows.
2024-7-13
johansenfoto
Norway
franksstudio Posted at 7-13 22:34
Remember to always wait for many seconds (up to 30 maybe) before removing any card/cameras after files have been accessed, or it can damage the card. So will think that's what have happend.
2024-7-14
franksstudio
johansenfoto Posted at 7-14 07:09
Ah yes I did not no, I will try that thanks.
2024-7-14
Iancraig10
I never thought of that. Corrupting the card! To be sure, you can right click and then 'remove safely'.
2024-7-14
johansenfoto
Norway
Iancraig10 Posted at 7-14 07:39
Many people actually never think or know about how USB units works with the buffer transfer.
They actually always recommend using that remove safely function.
2024-7-14
franksstudio
johansenfoto Posted at 7-14 14:42
Interesting, I will test that remove delay, when my card is corrupted and I run chkdsk /f it always find an error in the bootsector of the card, after the repair it can be accessed again.
2024-7-14
FfoSuy
Singapore
I had experienced this and am trying to recall how I fixed the problem. There is a micro-SD card compatibility issue with how different systems format the cards. Always format the card within the camera to ensure it works fine with the camera, and never format it in MS Windows.
If the card is unreadable/ undetected in the camera after formatting it in Windows, try reformatting the card using an external formatting tool  (https://www.sdcard.org/downloads/formatter/) or from the card manufacturer. Good luck!
Note: Most importantly, the card need to be accessible in Windows/ Mac for you to do this.
2024-7-19
