Putting the craft in transport mode (travel Mode)
1158 2 2015-9-18
edlovrien.msn
I had problems putting the new inspire into travel mode to put back into the case.  It wouldn't work no matter what I did.  Just thought I would share what I found out if others are having problems.
I had it sitting on a table with a towel over it.  When I moved it to another surface it worked fine.
Make sure you take the camera off first, then flip the switch 4 times like it says.  If it doesn't work, move it to another surface.  Many are doing it with the camera on and making tables with slits in it or holding it.  you don't have to do that.   If nothing works, set it on your case and try it.  Thats what worked the best for me.
2015-9-18
GB44
Flight distance : 343848 ft
Works all the time if you just sit to on the case and put it into to travel mode.
2015-9-19
edlovrien.msn
Yes, case works great for it.  Thats what I was getting at.  Saw on another forum many people having the same problem so I posted it for info.
2015-9-20
